Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1978 F800
Old Jan 8, 2019 | 06:50 AM
u122423's Avatar
u122423
1978 F800
I have a 1978 F800 (digger derrick) it idles a lot and tends to load up, i bought a new holley carb (without a governor). I was wondering if anyone has put a electronic ignition, or new/ different distributor to give it a little hotter spark. The truck does not get drove much but does a lot, just idle time.
Old Jan 9, 2019 | 07:52 AM
big job's Avatar
big job
Float level too high, leaking float needle valve fuel pump pressure power valve leak. Distributor has nothing to do with loading or running rich. Not being nasty but new out of the box doesn't mean its turn key now a days.
1978 F800 most likely has a 4 barrel Holley on a 391 FT. I use to be a Holley freak then we have gone to Edelbrock 4 barrels for our 391s. what a difference. don't know where you are from but Holley's do not like
mid 30 degree and rain they load up they ice up black smoke ......................
Old Jan 9, 2019 | 06:07 PM
Spirit of '76's Avatar
Spirit of '76
What engine?
Old Jan 10, 2019 | 06:10 AM
u122423's Avatar
u122423
389 is what is says on the air cleaner
Old Jan 11, 2019 | 09:28 AM
Destroked 450's Avatar
Destroked 450
389 would have had a 2 bbl carb.
389, 390, 391 are all the same cubic in engine.
389 FT with 2 bbl carb
391 FT engine with 4 bbl carb
390 FE engine for cars and pickups
Throw a Pertronixs electronic ignition in the distributor, the hotter spark will clear up most of the fuel loading issue.
It takes a hotter spark to burn todays gas, if it idles a lot and sees very little road use swap the cold burning plugs it uses for something hotter.
Don't remember the Autolite number but in Champion the truck takes F10's, we swapped over to F9Y's like was used in cars.
This was done on a 71 L800 with 391, it's used to move trailers around the lumber yard, idles a lot and hasn't been out on the highway in over 20 years.
Old Jan 11, 2019 | 10:41 AM
Spirit of '76
Mallory Unilite Distributor part # MAA-3760401
Call summit racing to confirm.
Old Jan 11, 2019 | 10:49 AM
Destroked 450
That numbers no good
Mallory #MAA-3755301 is the dist for a Ford FE engine but will no work in a FT engine without installing a bushing in the block and and modified oil pump drive.
Old Jan 11, 2019 | 11:05 AM
Spirit of '76
https://www.summitracing.com/parts/maa-3760401
Old Jan 11, 2019 | 12:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
389 is a "detuned for smog" 391. ALL 389/391's came with Holley 4V's.
Pic: 1973 389/391 on previous page.
Old Jan 11, 2019 | 06:47 PM
Destroked 450
Guess the ones at the fertilizer plant had the intakes and carbs swapped out, not surprising they were bad about patching up stuff.
Those were the only trucks I ever saw with 389 labels on the air cleaner.
Had a couple of those engines out, they were the correct bore and stroke.
Old Jan 11, 2019 | 07:49 PM
85e150's Avatar
85e150
The swap to a 2150 or other fine non-governed 2bbl can be the answer to the OP's problem--a carb that always runs rich, tough to fool with, prone to power valve failure. Governed carbs idle off the secondary side, seems like a recipe for poor idle quality. My dad's 292 was always that way. 2bbl made a nice difference, without any perceived loss of power. ymmv!
JWray707
13
Feb 23, 2019 06:03 PM
Fredf250
Jan 29, 2013 08:50 AM
The67Beast
Sep 20, 2006 02:12 AM
hotrod_ta
37
Jun 10, 2005 12:21 AM
trapper270
Sep 29, 2003 09:13 PM
