High pitched squeal
Old Jan 7, 2019 | 04:21 PM
dogdays's Avatar
dogdays
High pitched squeal
Comes from under the truck 2007 F150 4WD when I start out in the morning. I don't think it's the engine because it doesn't change pitch with rpm. I have tried coasting in Neutral and it's still there. It doesn't go away when I press on the brakes. It lessens when I lightly accelerate and increases in volume when I let off the gas or am driving constant speed. After a while it goes away but is back on the next startup.
First I thought idler pulley, then I thought rear brake pads are worn and the little metal finger is rubbing on the disk, now I'm tending to look at U-joints.
Any ideas?
R.
Old Jan 7, 2019 | 07:45 PM
stephen.osborne1's Avatar
stephen.osborne1
Could be a parking brake shoes let loose inside the rear rotor.
Davparks2
Jan 2, 2018 11:05 AM
truckerbear
May 25, 2012 09:31 AM
Chesapeake Bay TJAM
1997 - 2003 F150
Nov 29, 2010 10:59 PM
MTDewX
Dec 9, 2008 09:49 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
Feb 4, 2004 03:14 AM
