Chip Identification
Old Jan 6, 2019 | 08:04 PM
EddieA2746's Avatar
EddieA2746
Chip Identification
Hi everyone,
Nice forum....1st post. I am trying to help my dad with his truck ( 2000 F250 150k) and I am trying to identify a chip that I pulled off the computer. Turns out this chip end up causing a random stall/running issue and using google I cannot seem to find anything like it. The chip worked pretty well for the 18 years it was installed so I am trying to find a replacement with the same performance because with the chip removed from the truck is just not the same truck performance wise. The chip from what he tells me was purchased from the dealership in 2000 as a demo and it was installed when he purchased it so I assumed it was an ford option but I cannot find any info so that seems to be not the case.
Attached in a pic of the label. It is completely in cased in a green coating/plastic.
Thanks if you can help,
Eddie
Old Jan 7, 2019 | 08:35 AM
Colorado350's Avatar
Colorado350
Welcome to FTE.
Since the chip had issues, chuck it and invest in new technology and tuning knowledge. Look at a Hydra tuner then you can try different tunes from different tuners without pulling the chip, you simply download them from your computer.
Old Jan 7, 2019 | 01:46 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Same advice as above, get a modern chip with modern tunes. Switching tunes on the fly is pretty nifty. Here's a comprehensive thread for background reading on chips, but bear in mind that info is 5 years old. Tunes and hardware keep evolving.
BTW I don't think that is OE ford item, more of a Superchips knockoff if this thread is to be believed.
Old Jan 7, 2019 | 08:15 PM
EddieA2746's Avatar
EddieA2746
Yea, I have been researching the dif. programmers...etc. Now I have decide which one to go with. My dad is not gonna be the one to switch between dif "settings" so just need to make sure I can just get something that is close even if it has multiple ones and leave it set to that. I was just curious if it was known what that chip did as far as boost/power etc but I guess there is not really a way to know unless I knew who sold/programmed/installed it.
Eddie
Old Jan 7, 2019 | 08:27 PM
Colorado350
Eddie,
Let the old chip go and start researching the new options available. My guess is you’re going to be pleasantly surprised by the new tunes available for the truck. The Hydra allows for 15 tunes plus stock and no start. Load 5 or 15 your choice. The TS6 allows for 6 tunes, programmed by the tuner you choose, you send the chip in they program it and you install it.
Old Jan 8, 2019 | 03:01 AM
pirate4x4_camo's Avatar
pirate4x4_camo
I don’t know if anybody still does “chips” but you could sent the PCM to Jonathan and have him install a single modern performance tune on your pcm.
when you email him send him a pic of your chip, he might be interested in it if it actually a Ford chip and not just some knockoff a less then scrupulous dealer was offering.
https://www.dieseltechchatt.com/pages/about-d-t-c
afmedic
Sep 14, 2017 07:05 PM
ccarrier
34
Nov 11, 2010 09:02 PM
Rich in CO
Mar 6, 2006 10:59 PM
