Sanding and the Compressor
Old Sep 28, 2003 | 04:37 PM
Backroads_Jack's Avatar
Backroads_Jack
I am new at this sanding stuff. I have been trying to sand my hood, because it has at least five layers of paint. But I am having trouble gettin my 5.5 HP Craftsman Air compressor to stay above 90 psi. I set it to 90 psi then I start to sand for about three minutes then the pressure drops down to about 45 psi. During them three minutes I can get alot sanded, then I hear the motor kick in and am back to 45 psi and can barely get anything done. So I have to keep waiting till I get back up to 90 psi. I have even tried to set it at 120 psi. No luck. I am about to throw the #@^& out the window.
Please someone help me.
Thanks,
JAck
Old Sep 28, 2003 | 06:45 PM
Aekisu's Avatar
Aekisu
<br>
Your p.s.i. reading is the symptom, not the disease.
The drop in air pressure occurs because the tool you are using demands more air than the compressor can provide. Although the compressor can produce 120 p.s.i., it does not produce the volume (measured in C.F.M.).
Craftman makes a good air compressor. There is nothing wrong with the brand. Your compressor is just too small. I didn't get my air compressor purchase correct until I bought my 4th machine. It was an expensive learning curve.
Air tools like sanders, die grinder, impact wrenches, and etc. use a great deal of air. Most of them require more than what your compressor can supply. It's not usual to see C.F.M. (cubic feet per minute) requirements of 12 - 18 at 90 p.s.i. I would hazard a guess your compressor is putting out about 6 C.F.M. at 40 p.s.i. At 90 p.s.i., you are probably getting around 4 C.F.M. The actual figures are probably listed on the compressor.
Old Sep 28, 2003 | 08:36 PM
jor's Avatar
jor
Aekisu is correct, however, I also have a 5.5 hp Sears model and it will run a sander. It says it will provide 6.4 at 90. Should be written on the side of the compressor.
jor
Old Sep 28, 2003 | 09:01 PM
darkman's Avatar
darkman
My five horse couldn't cut it any longer (wore out) so I bit the bullet and bought a 7.5hp that really gets the job done. It isn't the best brand and it may fail sooner than some but I can sandblast all day and it doesn't drop below 90 psi. I am very pleased with it. You can get it at Sears as a Cambell Hausfeld or at Home Depot as a Huskey. Same compressor. The final word is that my neighbors ears burn no more as I don't have to cuss while using the air compressor.
Old Sep 28, 2003 | 09:44 PM
Backroads_Jack
Thanks
Thanks for the help. Not what i wanted to hear, but I guess it true. I guess I will be at sears or somewhere buying a new aircompressor.
You guys are great. Thanks for the help.
Thanks,
JAck
Old Oct 5, 2003 | 10:47 AM
oldroady's Avatar
oldroady
you can get verticle 60 gal. two cyl. compressors in the 11.5 to 13 cfm range for under $400.00 bucks now. only way to fly.
Old Oct 5, 2003 | 05:55 PM
darkman's Avatar
darkman
It won't cut it for sandblasting. Not enough SCFM!
Old Oct 5, 2003 | 06:02 PM
stepman's Avatar
stepman
I don't know about that, my 5.5 craftsman will keep up with my blaster but with my da sander it won't even come close.
Old Oct 25, 2003 | 08:00 AM
uk1050's Avatar
uk1050
WHEN I STARTED OUT I WAS USING THE SAME COMPRESSOR AND HAD THE SAME PROB. THE ONLY FIX.....BUY A NEW AIRCOMPRESSOR. I HAVE A 60 GAL 6 HORSE AND IT KEEPS UP WITH EVERYTHING I USE BLASTERS CABINET AND PORTIBLE AND ALL THE AIR TOOLS THEY MAKE.
Old Oct 25, 2003 | 01:04 PM
stepman's Avatar
stepman
You will get no argument here. Bigger is better. I've been rebuilding mine about every 2 years for a 35 dollar kit The wife can't understand why I want to go buy more tools if I can keep doing that. I guess it will just have to expire for good. Maybe it'll have an "unfortunate incident"
Old Oct 25, 2003 | 04:12 PM
darkman's Avatar
darkman
Stepman,
What size nozzle are you using? It must be small if if 11 cfm is all that is required. My glass beader has a 5/16" nozzle and needs at least 19 cfm and my sand blaster uses a little less.
Sand blasting my frame did my last compressor in. Not terminally but I had to rebuild it twice in two weeks so my better half suggested that a better compressor was in order. I'm a lucky guy.
Old Oct 25, 2003 | 05:35 PM
stepman's Avatar
stepman
darkman, My nozzles are 1/8". My beadblaster is also bigger but it keeps up pretty good. My sandblaster works good until it wears to about 1/4", Then I have to wait on the compressor or change tips. It doesn't remove a lot at a time but it does okay. When I bought the compressor, the bigger ones cost about twice what they do now so my next one(which shouldn't be too far away) will definately be alot bigger.
Old Oct 25, 2003 | 06:06 PM
Huntsman's Avatar
Huntsman
It's true CFM is the determining factor in most air tools because even the little compressors can pump up to 100+PSI, but be also aware that different tools vary considerably in operating CFM. The same size die grinder can range from 3.5 CFM to 9CFM depending on power and quality.
