Another LIght Thread
Old Jan 1, 2019 | 09:40 AM
ATC_F350's Avatar
ATC_F350
Originally Posted by BillyE
It’s a very substantial improvement. It’s not easy to quantify. I’d say the lighting power is every bit as good as anything I’ve driven. I still don’t love the pattern. I may play with mine a little more.
Which ones do you have, BillyE?
Old Jan 1, 2019 | 11:08 AM
Truckie256's Avatar
Truckie256
Mine are the ones with fans... I added the in line resistors.. plug and play..... 6.2L... washer filler tube off on driver side...I loosened and peeled back wheel well liner and went up from bottom on passenger side.... 3 5" front/ 1" rear..level lift, I just adjusted the housings all the way down, nobody flashes me
Old Jan 1, 2019 | 01:08 PM
77mmbass's Avatar
77mmbass
Originally Posted by Poncho450
Relatively easy install depending on which engine you have. I've done it a couple ways with a 6.2. Did it twice because I tried a set of Sylvania halogens first. Wasn't happy with that result.
Removed the whole grille the first time. Removed just the filler neck on the washer tank to access the driver side the second time. Second time was obviously easier and faster. Passenger side wasn't much of a problem without removing anything. Maybe a diesel owner could check in and let you know how they go as I know they have 2 batteries.
They do seem to require some effort to twist and pull out. Make sure you have the LED chips oriented to the 3 o'clock and 9 o'clock positions for correct beam placement. Make sure that the factory seals come off and aren't stuck to the headlight housing. You're not getting a new bulb in there with 2 seals.
Thanks, I have the 6.2
Old Jan 1, 2019 | 04:06 PM
Imadentguy's Avatar
Imadentguy
EZ PEEZY just installed the beam techs this afternoon. 20 minute install.
Roger T. Pipe
Apr 8, 2019 02:04 PM
mikeo0o0o0
Dec 18, 2011 06:03 PM
ID1982F150I6
Idaho Chapter
20
Nov 20, 2010 05:47 AM
shane4golf
2004 - 2008 F150
Jan 28, 2007 10:23 AM
Bryan Baum
1997 - 2003 F150
Aug 7, 2000 09:57 PM
