Another LIght Thread
Old Dec 31, 2018 | 09:48 PM
ATC_F350's Avatar
ATC_F350
I know its been talked about quite a bit, but anyone who has seen light configurations how would you rate them? By this I mean if Halogens are a 100 to start the scale are the Beamtechs a 120 or a 150, the factory leds a 160 or 200 or what in your judgement. I've seen a video and the replacement leds seem way better than Halogens, but I (probably we) would just like to hear some real world experiences. I'm looking at the factory leds, but you have to get the Lariat Ultimate Package and Blis. Don't know if its worth it.
Thanks
Old Dec 31, 2018 | 10:21 PM
Truckie256's Avatar
Truckie256
never had FACTORY LED, but beamtech, to me, is a 1000 compared to halogen
Old Dec 31, 2018 | 11:38 PM
Mkos1980's Avatar
Mkos1980
Ditto with the beamtechs!
Old Jan 1, 2019 | 02:27 AM
77mmbass's Avatar
77mmbass
Are the beamtechs plug and play? Easy install?
Been thinking about going LED
Old Jan 1, 2019 | 06:10 AM
PatsfanTN's Avatar
PatsfanTN
They are plug and play
Old Jan 1, 2019 | 08:18 AM
Poncho450's Avatar
Poncho450
Relatively easy install depending on which engine you have. I've done it a couple ways with a 6.2. Did it twice because I tried a set of Sylvania halogens first. Wasn't happy with that result.
Removed the whole grille the first time. Removed just the filler neck on the washer tank to access the driver side the second time. Second time was obviously easier and faster. Passenger side wasn't much of a problem without removing anything. Maybe a diesel owner could check in and let you know how they go as I know they have 2 batteries.
They do seem to require some effort to twist and pull out. Make sure you have the LED chips oriented to the 3 o'clock and 9 o'clock positions for correct beam placement. Make sure that the factory seals come off and aren't stuck to the headlight housing. You're not getting a new bulb in there with 2 seals.
Old Jan 1, 2019 | 08:27 AM
Spooledsrt's Avatar
Spooledsrt
In for night time driving pictures/vids and which beamtechs are used. Are they all fanless and 6500k?
Id really like the factory led headlights at some point but at 2k its not happening.
Old Jan 1, 2019 | 08:31 AM
RegularCabPlati's Avatar
RegularCabPlati
These are Headlight Revolution's Supernova V.4's on high beams with V.4's fog lights, Bambi mode turned on and switchbacks in the turn signals
Old Jan 1, 2019 | 08:33 AM
Maiden666's Avatar
Maiden666
Lift? Level? After you put them in, did you adjust the headlights? Thanks!
Old Jan 1, 2019 | 08:34 AM
Uzumati's Avatar
Uzumati
With the 6.7 it is a little tight but can be done with just the filler neck removal for the driver side and the intake cowl snaps out with 1 push pin on passenger side. Definitely line the bulbs up at 3 and 9 like ponch said, I just lined the bulbs up at the 3 an 9 position before I inserted and then turned backwards till the bulb slid in, once locked in position the bulbs ended up at 3 and 9 without adjustment.
Old Jan 1, 2019 | 08:35 AM
Poncho450's Avatar
Poncho450
Of the 3 versions I saw on Amazon, all are 6500k. All are fanless. 2 are 8000 lumens, 1 is 10000 lumens.
Old Jan 1, 2019 | 08:38 AM
RegularCabPlati
all stock and didn't have to adjust anything. the low beams are bright and not out to far that you get flashed
PatsfanTN's Avatar
PatsfanTN
There’s a thread on here detailing how. But I have the 6.2 and didn’t have to do anything on the drivers side. On passenger side, remove air intake to get to the top one. For the bottom, get behind the felt liner and you can reach it. Easy
Old Jan 1, 2019 | 08:40 AM
Maiden666's Avatar
Maiden666
Ok, thanks!
BillyE's Avatar
BillyE
It’s a very substantial improvement. It’s not easy to quantify. I’d say the lighting power is every bit as good as anything I’ve driven. I still don’t love the pattern. I may play with mine a little more.
