Air Filter Options
Old Dec 30, 2018 | 10:38 AM
dhoff024's Avatar
dhoff024
Air Filter Options
Just hit 34k miles in my 16 F150 with a 2.7 and looking to replace the air filter. Not looking at a CAI or anything just looking at replacing the air filter and I was looking at getting opinions on if it's worth going to something like an AEM dry flow filter or just sticking with OEM or equivalent? My dad has a 17 with the 3.5 and he was wondering the same thing so I figured I would post to see what everyone's thoughts are on it or if anyone has switched there's to something other than OEM and what they think. Thanks in advance!
Old Dec 30, 2018 | 10:58 AM
idrive's Avatar
idrive
I'd just use the OEM.
We know it works well, priced right and easy to find.
I would also argue that there are no benefits to other "types" of filters.
Old Dec 30, 2018 | 12:10 PM
NASSTY's Avatar
NASSTY
I use OEM as well.
Old Dec 30, 2018 | 12:19 PM
alloro's Avatar
alloro
And your argument would be spot on! Between the MAF and the O2 sensors the air/fuel mixture is adjusted to maximum efficiency even as airflow might be restricted through the air filter. All a high flow air filter like K&N does is help at the top end of the RPM range which most of us don't drive at.
Old Dec 30, 2018 | 02:27 PM
scott91370's Avatar
scott91370
I picked up one of the AEM dry because I was able to get it for under $30 shipped and a regular paper filter is somewhere around $17. After one cleaning it will have paid for itself.
Old Dec 30, 2018 | 03:19 PM
onug's Avatar
onug
The Youtuber Engineeing Explained recently did a video on various drop-in filters. His (limited) tests did show a small HP benefit from an aftermarket filter. I’m of the opinion that the increased flow comes from reduced filtering, so there’s no free lunch. So it’s all about what you are looking to do.
For me, I believe Ford has optimized their filter to give the best flow and filtration. Given the power and MPG “wars” betwen the various OEM’s, Ford would never leave a poorly designed filter in the mix. If anything, the filter might be light on filtering to favor HP. But that’s just my “engineer working for a large corporation” attitude showing.
Old Dec 31, 2018 | 07:02 AM
ghunt's Avatar
ghunt
I'm a fan of the dry media filters, if you can find a good deal on one. Sometimes they are a little expensive though.
Old Dec 31, 2018 | 07:08 AM
advocate's Avatar
advocate
Stick with a good paper filter, Fram, Wix, AC Delco, Napa etc. They all seem to have more pleats then the motorcraft and are about twice as think. There is a couple HP to be had with an AEM for more money but is it really worth it? These paper filters filter so well with 99+% efficiency ratings. The air filter is the most important filter in your truck, use a good one, and don't disturb it. Leave it in for what you are comfortable with. Ford's interval is 30k miles. So if you want change it out every year and be done with it. Cheap insurance for your engine.
Old Dec 31, 2018 | 01:37 PM
pikapp's Avatar
pikapp
I believe I recall someone on this forum saying some time ago the MC filter was as good as any other on the market and probably better for the EB engines, since the turbo's are very touchy when it comes to particle debris (or as Aussie broadcaster Leigh Diffy would say..day bree).
Old Jan 6, 2019 | 04:52 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you don't add more filter medium with a larger filter, then all you're doing is trading filtration for flow.
The only way to increase flow without sacrificing filtration is by getting a larger filter.
JRD761
6.7L Power Stroke Diesel
19
Aug 30, 2015 07:20 AM
navistar2000
Oct 8, 2007 01:10 PM
Kennicol
Modular V10 (6.8l)
Mar 12, 2005 01:45 PM
treb
1983 - 2012 Ranger & B-Series
Aug 22, 2003 04:19 PM
