Engine swap
Old Dec 29, 2018 | 10:10 PM
Imallearsfor59s's Avatar
Imallearsfor59s
Engine swap
Hey how are you all? I have a 59 ford f100 and it has a inline 6 300 in it how hard would it be to drop the 302 in it what would I have to change or would it slide right in with new motor mounts installed
Old Dec 30, 2018 | 11:59 AM
moonley's Avatar
moonley
You would need new motor mounts and engine perches. Bell housing pattern between the 300 and SBF is the same but the 300 shares engine perch configuration with the FE 332/352/360/390 family of engines.
Old Dec 30, 2018 | 03:51 PM
Imallearsfor59s
THanks ill look into all of those items
Old Dec 30, 2018 | 04:19 PM
f5fordgirl's Avatar
f5fordgirl
Also you will need the V8 flywheel or flex plate with the correct balance for the year it is.
Old Dec 31, 2018 | 01:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Imallearsfor59s
I have a 59 ford f100 and it has a inline 6 300 in it.
If it has a 300 I-6, it was swapped in. It wasn't available until 1965.
1954/64 would have a 223 I-6, the intake/exhaust manifolds are located on the left (drivers) side.
240/300 I-6 intake/exhaust manifolds are located on the right (passenger) side.
240/300 mount completely different than the 223.
Old Dec 31, 2018 | 02:02 PM
Imallearsfor59s
So are you saying it should be easier to swap or what
Old Dec 31, 2018 | 02:05 PM
NumberDummy
So are you saying it should be easier to swap or what.
What I'm saying is, if your truck has a 300, it was swapped in. 300 was not available until 1965.
See post #5 for the difference between a 223 I-6 that would have been original and the 300.
Old Dec 31, 2018 | 02:07 PM
Imallearsfor59s
Yea I understood that and I appreciate the insight
oldmountainfarm
Aug 25, 2012 12:24 PM
73FordF100
17
Jul 25, 2011 03:36 PM
surfcraft
Sep 3, 2010 11:04 AM
78 explorer
Jul 9, 2009 08:21 AM
mark alderson
Apr 4, 2006 12:01 PM
