New Vilano 360 RL
Old Jan 16, 2019 | 09:11 AM
jimbonnet's Avatar
jimbonnet
Nice Rig! We have a 2019 375FL. I didnt opt for the discs right away but did get the 8K Axles and H rated tires.
Good luck with your rig.
Old Apr 23, 2019 | 06:41 AM
prof nomad's Avatar
prof nomad
That is a super nice trailer. Roughing it in style for sure. Good call on the upgraded axles and brakes, that's a lot of payload you have. Did you upgrade the tires also? The reason I ask is I upgraded to load range G tires on my gooseneck I took delivery on in January of 2017. Fast forward to last Friday when I picked up a nail somewhere along I-95 in South Carolina. I made it to a Goodyear commercial service shop in Savannah to get it changed. Upon further inspection the tech discovered that not only was there a nail in my tire but the rim had a small crack about 3" long right down the center. The tech said it could have been from the heat build up caused by running it at low pressure. Thankfully, for the tire and ultimately the load, I-95 was a parking lot most of the way southbound to the Ga. line where it opened up to 3 lanes. That's probably the only thing that kept the tire from blowing out was the reduced speeds. Back to the rim: When I ordered the trailer I ordered 7k torsion axles, elec/hyd discs, and load range G tires. Evidently the trailer was shipped with load range E tires because the rims that are on it are only rated for 3750#. So, if you upgraded the tires make sure the rims are the proper ones.
Sorry if this post sounds discombobulated, we've had a steady parade of customers in here this AM. No complaints!
The upgrade came with H Rated Tires. I also run a Tire Minder System to keep an eye on the tires.
Old Apr 23, 2019 | 06:42 AM
prof nomad's Avatar
prof nomad
Originally Posted by sneil
Very nice indeed. We're looking at the Vilano and the Beacon lines as well. Haven't decided for sure yet, but the we like the full body paint offered in the Beacon line. I was curious if you could let me know what color you have for the cabinetry? I like the color combination you have. None of the brochures indicate which ones are the amber glaze or english chestnut (easy to figure out the mocha).
Thanks and that's a very nice looking rig!
My woodwork is the English Chestnut.
Old Apr 29, 2019 | 07:27 AM
kevin211's Avatar
kevin211
yes this brand is a "spin off" off of tiffan, the son runs the the 5th wheel line up, all high end just like the MH
Old May 1, 2019 | 02:41 PM
digz's Avatar
digz
The upgraded axles a dealer option? I dont see it on the Vilano website
Old May 1, 2019 | 02:49 PM
jimbonnet's Avatar
jimbonnet
The upgraded axles are a factory option on 2020 order sheet. Prior to that you had to ask. Vanleigh is pretty good about doing whatever you want so call them if you have special requests.
Old Jul 24, 2019 | 10:21 AM
InkMing's Avatar
InkMing
Very very nice upgrade Prof! Now. Where are the tales of the road trip? School should be out now. Looking forward to another 3 month on the road visual recap.
Kevin's dad
Nov 24, 2018 09:27 PM
kenny nunez
20
Oct 29, 2018 05:17 AM
rangerbait
All Things Towing
18
Jul 14, 2015 02:51 PM
novatattoo
Jul 2, 2009 09:05 PM
gr8scott72
Jun 29, 2009 08:10 AM
