Transmission
Old Dec 28, 2018 | 06:04 PM
carl2591's Avatar
carl2591
wonder if it would be a good idea on truck with some miles, some of them towing miles, to go through the effort to drop valve body, find the bolts and remove them, add some maybe blue locktit and reinstalled at proper torque.. ?? sounds like an expensive problem that can be corrected quite cheaply. not having to be towed somewhere is alway better in my book. who how hard is this to do?? any video of the procedure??
Originally Posted by Pastor Jared Parmley
Does anyone have a pic of the feed bolts that could be loose? Thanks
Old Dec 28, 2018 | 06:26 PM
FordTruckNoob's Avatar
FordTruckNoob
Here you go.
Per the manual: "After removal, discard the feedbolts. The bolts will not retain torque specification if reused. "
Old Jan 1, 2019 | 08:01 PM
Pastor Jared Parmley's Avatar
Does anybody know the part number to the feed bolts?
Old Jan 1, 2019 | 09:07 PM
mueckster's Avatar
mueckster
The reason they say not to reuse them is they are coated with a dry threadlocking sealant. If the threads of the Feed bolts, Center Support, and OD-Intermediate Cylinder are cleaned & dried, a threadlocker can be applied and bolts retorqued. One of the reasons the bolts loosen is wear on the Center Support pads; causing movement as the clutches apply. Retorquing them can buy some more transmission time, but does not address the root cause.
Old Jan 1, 2019 | 09:31 PM
Do JW or BTS Transmissions solve this problem with a new center support?
Old Jan 2, 2019 | 09:03 AM
BLUEMAX65's Avatar
BLUEMAX65
Sam Wyse does. Not sure about the others. From the link I provided to you.
DUAL LOAD CENTER SUPPORT MACHINED FOR MORE STRENGTH
Old Jan 2, 2019 | 10:49 AM
mueckster's Avatar
mueckster
Here are some pics of the wear on the Center Support Housing and what causes the "walk" within the Trans Case and loosening of the Feed bolts. Also shown are the solutions to this: Machining of this Housing and the addition of a Spacer Ring to eliminate slack and increase surface area contact. Some go a step farther by machining the Center Shaft smooth and the inside of Support Hub to add a bushing w/ oil grooves. I am not a fan of the bushing add-on as you can see what can happen in the last pic. I went with the machined aluminum Housing/stock steel Support Hub, new bearing, and a cryo'd Center Shaft after it failed. I haven't had any issues with just using the machined Housing/Spacer Ring combo.
Jun 8, 2019 09:21 AM
PPrash
Feb 15, 2019 04:21 AM
JoeyM
Oct 10, 2015 05:16 PM
timbuctooCal
Nov 15, 2011 11:52 AM
joeycyph56
Sep 7, 2010 02:23 PM
