Sponsored by: Real Truck
Deceleration vibration.
Old Dec 27, 2018 | 04:22 PM
Ecleary's Avatar
Ecleary
I have a 2005, F250, and when decelerating from highway speeds, I get a severe vibration in the steering wheel between 70 down to 35 mph. If I keep light throttle pressure, the vibration goes away. Any ideas of a cause would be appreciated.
Old Dec 27, 2018 | 05:11 PM
Djosbun's Avatar
Djosbun
Deceleration causes a weight shift in a vehicle. Does the vibration get worse when you apply slight brake pressure? If so, that’s all the proof you need that there is something worn and/or loose in the front end. Get the front wheels off the ground and start checking components.
— Dave
Old Dec 27, 2018 | 06:22 PM
Ecleary's Avatar
Ecleary
Brake pressure doesn't change the vibration. I also just installed new pads and rotors, but does not feel like a warped rotor.
Old Dec 27, 2018 | 07:56 PM
Sir Kayakalot's Avatar
Sir Kayakalot
There are so many things that could cause this. Check every part on the the front end for wear. Gotta get the wheels off the ground and wiggle em to see if there’s any play. Check all of the steering components. Have someone turn your steering wheel slightly both directions while you are underneath with your hands on various components. Don’t rule out the u-joints
Old Dec 28, 2018 | 11:01 AM
schmidm90's Avatar
schmidm90
Trailering
I had a similar issue which turned out to be the u-joints in the front end.
Old Dec 28, 2018 | 05:34 PM
maticuno's Avatar
maticuno
Lots of potential issues. Ball joints, wheel bearings, steering arms/rods ends and bushings. First thing to try, though, is a tire rotation. If it stops after that, then the tires that were on the front need to be road force balanced.
Old Dec 28, 2018 | 06:28 PM
99f350sd's Avatar
99f350sd
Mine has a vibration on deceleration. Cant nail it down...has to be rear driveshaft or transfercase. barely noticable.
Old Dec 30, 2018 | 11:17 PM
droldsmorland's Avatar
droldsmorland
Decel vibes are usually U joints. You may need to disconnect the shafts and articulate the joint as a visual inspection won't always find a seised u joint cup.
For the hell of it inspect all 4 caliper bracket slider pins (8 pins).
Inspect chassis suspension and steering components.
Check pinion bearings on both axles for play. Should be undetectable movement by hand.
04explorerlimited
Mar 29, 2012 06:51 AM
stu78
2004 - 2008 F150
Jun 18, 2007 11:50 AM
wants_a_power_stroke
Aug 1, 2005 05:02 PM
umtigers
May 27, 2005 04:06 PM
Phobia16V
Jun 11, 2003 10:51 PM
