2011 F250 truck shell wiring question
Hello, I recently bought a used ARE shell for my 2011 F250 diesel. The shell has the third brake light with blue and black wires coming out of it. Where is the best place to hook this up to my truck? I’ve heard there might be a loop installed from the factory for just such a purpose. Any thoughts or input would be greatly appreciated! 🍺
There should be extra wires near the spare tire for just this purpose. I believe the ARE website even has a write up of using them. That's where mine is connected to.
After a quick look at the ARE website, they've apparently taken that info off it. Any dealer should be able to give you the specific info. But you should find a bundle of wires there above or near the spare tire that has a brake signal wire in it. If you got one with the power locking rear glass, the signal for it comes from the passenger side front door sill plate or kick panel area.
on
Don't splice in to the truck tail light wiring or you will get a blinking brake light when you use the turn signal.
There is allegedly a blue-orange wire under the hood near the hood open switch on the driver side for a brake signal/power connection.
The older trucks had a green wire poked out of the tail light harness with a label CHMSL for center high mount stop light.
If you are unable to find either of these, the truck should already have a trailer harness back there so you could splice off the trailer brake wire. This may also be preferable to running another wire to the back of the truck.
boeingoing
1999 to 2016 Super Duty
02-09-2010 02:38 PM
fns906
1983 - 2012 Ranger & B-Series
06-19-2008 12:19 PM
