Engine bogging
Old Dec 26, 2018 | 10:44 PM
quinton144's Avatar
quinton144
Engine bogging
so for quite a while I’ve been tuneing and adjusting the Edelbrock 8867 on my 390 FE just recently I got it sounding just right idles good and sounded great when reving in netural. But when I took it for a drive it bogs down at the beginning of each gear excluding the granny first and reverse. Almost sounds like it starts missing hard at the beginning of 3rd and 4th especially any suggestions? Thanks a lot.
Old Dec 27, 2018 | 09:39 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
First, WELCOME to FTE!
Sounds like not enough accelerator pump. But, let's get some basic info first.
Is it still points ignition? Does the vacuum advance work? Is the distributor really old? This could be a problem with the upper bushing in the distributor causing the points gap to vary widely, especially when you first get on it, which causes the vacuum advance to kick in.
Old Dec 27, 2018 | 02:43 PM
quinton144's Avatar
quinton144
Thanks for the welcome man. That’s what we thought at first. it now has a brand new hei distributor now with the vacume advanced hooked up
Old Dec 28, 2018 | 01:04 PM
krewat's Avatar
krewat
Is the vacuum advance connected to "ported" vacuum or manifold vacuum?
Light Doug
Nov 19, 2018 05:20 AM
bluestang65
15
Jun 13, 2015 12:04 PM
Drac
Nov 24, 2010 06:44 AM
ADSf100
Mar 21, 2003 10:53 AM
roddy reid
Nov 26, 2001 12:37 AM
