Sponsored by: Real Truck
Possible head gasket?
Old Dec 26, 2018 | 08:42 AM
gabriell12123's Avatar
gabriell12123
Is it possible for a head gasket to blow in a oil passageway and into a cylinder without mixing with coolant? I have low compression in cylinder 5 and blue smoke but no coolant loss. I had a spark plug blow out of this cylinder at one point in time.
Old Dec 26, 2018 | 09:12 AM
redford's Avatar
redford
FTE Leadership Emeritus
I guess it's possible, but I would run a compression test on all cylinders, including #5. A more likely scenario is that maybe something got into the combustion chamber during the spark plug ejection event and damaged something.
Old Dec 26, 2018 | 09:28 AM
gabriell12123
thanks for the quick reply redford, I ran a compression test on all cylinders already and cylinder 5 is the only one with low compression, that plug didn’t break and the threads weren’t damaged somehow, somebody just didn’t tighten it down all the way. I can do the work myself I was just curious if anybody had any problems like this before. It’s a 5.4 triton btw
Old Dec 26, 2018 | 12:29 PM
redford's Avatar
redford
Process of elimination:
1. It has spark.plugs.
2. It's in a Super Duty.
3. It ejected a plug.
Therefore, it is a 1999-2004 2V 5.4L or 6.8L Triton.
If #5 is showing low compression, you might try a leakdown test, but at the end of the day you'll be doing a teardown anyway, or at least pulling 1 head.
Old Dec 26, 2018 | 03:40 PM
gabriell12123
you got it 99 2v, I just hope it’s not worn rings
Old Dec 26, 2018 | 07:17 PM
SuperDutyScaler's Avatar
SuperDutyScaler
It's a 99-02 problem. Ford fixed that issue for 2003 and 2004 trucks
Old Dec 26, 2018 | 07:21 PM
maticuno's Avatar
maticuno
Not 100% correct, but close. They fixed the problem on build date 11/2002 and newer. My 10/2002 build date 2003 has the 4 thread heads.
Old Dec 27, 2018 | 06:00 AM
gabriell12123
Have y’all heard of a head gasket going bad at an oil passageway? I know the head gaskets leaking oil is common but my motor doesn’t look oily on the exterior btw I forgot to mention all the other cylinder where 140-150 except this one
Old Dec 27, 2018 | 07:09 AM
Fal-308-Win's Avatar
Fal-308-Win
Xxxxxxxxxx
Old Dec 27, 2018 | 12:13 PM
redford's Avatar
redford
Me too, but like I said, at a minimum it is time to remove at least one head and get some eyeballs on what is going on.
Old Dec 27, 2018 | 12:55 PM
maticuno's Avatar
maticuno
Do you have access to a bore scope or anything that will help you get a look in there through the spark plug hole?
Old Dec 28, 2018 | 10:01 AM
gabriell12123
I bought head gaskets and bolts today, but I’d still like the get valve seals so I’m gonna go ahead and get everything tore down and hopefully pieced back together soon, kinda sucks because I just redid the timing and installed a new oil pump and was gonna replace the head gaskets then, but decided not to because I was to my oil pump went out.
Old Jan 2, 2019 | 08:28 AM
redford's Avatar
redford
I was going to suggest a new timing set, since you are pulling the heads anyway, but I see you have that covered.
Old Jan 2, 2019 | 09:09 AM
gabriell12123
Yes it is, I’ve got both heads off and stripped to be shaved but before I do that I’d like to get a straight edge and a feeler gauge to see if it even needs to be shaved, Tell me what you think about this head gasket. I didn’t see any obvious signs that the gasket was bad but valve seals were definitely worm (barely holds the valve up). What’s the best step to take next?
Old Jan 2, 2019 | 11:08 AM
redford's Avatar
redford
I am looking on my phone, so detail isn't great, but it looks OK.
