Sponsored by: Real Truck
Possible head gasket?
Old Jan 3, 2019 | 12:30 AM
Evan_P's Avatar
Evan_P
Your next step should be to roll the #5 piston to bottom dead center and inspect the cylinder walls. Then have the heads checked by a machine shop to verify that the valves are sealing on that cylinder. You should have done a leak down test BEFORE removing the heads. That would have told you where your compression loss was.
Old Jan 3, 2019 | 08:15 AM
redford's Avatar
redford
FTE Leadership Emeritus
Check the valves on the #5 head to see if they are seating properly.
Old Jan 3, 2019 | 09:09 AM
gabriell12123's Avatar
gabriell12123
I already stripped the heads and cleaned the surface and my heads are flat (I checked with a straight edge and feeler gauge) valves are still out but I did replace all the valve seals. Cylinder walls are all in good shape, pistons had carbon buildup but are clean now, I just need to get a torque wrench so I can put my heads back on.
Old Jan 5, 2019 | 09:11 PM
gabriell12123
Can somebody tell me the torque specs and sequence for the head bolts?
truck crazy man
17
Feb 6, 2014 07:50 PM
Bill's2000X
Modular V10 (6.8l)
Oct 3, 2010 01:40 PM
zzjonze
1983 - 2012 Ranger & B-Series
Mar 30, 2010 06:06 PM
69oiler
Mar 5, 2006 03:07 PM
zoysia
Modular V8 (4.6L, 5.4L)
Jan 17, 2006 02:26 PM
