'12 E350 5.4L code P013A
Old Dec 25, 2018 | 05:36 PM
interstategar's Avatar
interstategar
Repalced the Bank1 sensor O2 sensor, but the ck engine light still comes on after driving about 140 miles. I've erased the code twice and this still happens. Also when the ck engine light isn't on the fuel gause reads 1/8 of a tank lower than it should. When the ck engine light comes, the fuel guage increases 1/8 of a tank, where it should be. Any ideas how to fix this, and the correlation between the gauge and the sensor?
Old Dec 25, 2018 | 08:39 PM
Philly driver's Avatar
Philly driver
Check the exhaust for leaks, also there’s another O2 sensor after the catalitic converter maybe that’s the one acting weird.
Besides that, I don’t know what the correlation could be with the check engine light and the gauge, hopefully some one else could chime in.
Old Dec 26, 2018 | 05:28 AM
JWA's Avatar
JWA
Actron's Code Lookup site shows this definition for DTC P013A: P013A-00 O2 Sensor Slow Response - Rich to Lean (Bank 1 Sensor 2). That being the only code you're showing would strongly suggest the down stream O2 sensor isn't working to spec. Link to the Actron site: Actron
Not sure what to think about the errant fuel gauge---could be related to the DTC through the CAN-bus system? Logic says it should be related but one never knows. Which reading seems to be most accurate relative to the actual fuel level you believe to still be in the tank?
Old Dec 27, 2018 | 10:08 AM
interstategar
When the ck engine light is on seems more accurate. I'm not positive the fuel guage reading is related to the O2 sensor. I'm having the van ck'd out at the shop I go to next week.
Old Apr 12, 2019 | 08:57 AM
interstategar
UPDATE: The problem was solved by installing a Motorcraft O2 sensor. The aftermarket sensor I bought was supposed to be up tp OEM standards but it wasn't. It was a Bosch. The fuel gauge had nothing to do with it at all, and is the sending unit in the fuel tank.
Old Apr 13, 2019 | 05:25 AM
JWA's Avatar
JWA
Its very strange the high quality of Bosch parts doesn't seem to impress Ford PCM's. I've read more than a few threads where that brand sensor has caused issues, switching to Motorcraft almost always solves the problem.
churioz
1983 - 2012 Ranger & B-Series
Mar 8, 2012 03:09 PM
keyul
1997 - 2003 F150
Nov 30, 2007 11:12 AM
plankofwood64
1997 - 2003 F150
Oct 8, 2007 02:52 PM
DANA60
Dec 21, 2004 08:14 PM
lw1955
1997 - 2003 F150
13
Mar 23, 2004 12:15 PM
