Help! Something stuck in spark plug well 4.6 V8
Hi everyone. My mechanic could not remove spark plug #8 he said there was a washer or something stuck in the spark plug well. I took a look myself but I can't seem to figure out what it is, I don't want to take out the spark plug and have that fall in the cylinder.
I took some pictures so if anyone knows what it is or if its safe to take out the spark plug please let me know. Thank you!
Anyone know how to remove the fuel rail in this e250 2007 van?
Can't really see if there's something loose in there -- when I did my plugs I stopped at a similar spot and panicked for 3 days.
Here's mine:
Mine's a 5.4, and that is a picture of the half plug that was left in there after the rest of it was broken off.
(you can see the scraps of ceramic in mine, which I cleaned with a shop vac before going at it with the Lisle extraction tool)
The extraction tool removed everything perfectly, even though I could make any sense of what I was looking at.
Here's mine:
Project how do I remove the fuel rail properly?
2. Relieve fuel pressure in the rail.
3. Remove the hold-down bolts.
4. You may need to disconnect the fuel lines from the rail.
5. Wiggle and pull on the rail until either it separates from the injector top or the injector comes out. All of them on that side will probably need to be disconnected in order to move the rail.
