Electric fuel pump
Old Dec 24, 2018 | 10:24 AM
adoublenickel's Avatar
adoublenickel
Electric fuel pump
Thinking about adding an in line fuel pump to replace the in tank pump that is going bad. Do I need to pull the old pump from tank or just disconnect power?
Old Dec 24, 2018 | 11:47 AM
f5fordgirl's Avatar
f5fordgirl
Most likely no, in-tank pumps have a set pressure for year and engine, unless you have the two pump setup, then you might get by with that, as it would only feed the high pressure pump.
Old Dec 24, 2018 | 11:50 AM
adoublenickel
Thank you.
Old Dec 25, 2018 | 05:05 PM
Hank85713's Avatar
Hank85713
dont know tried to use an electric pump to defuel the tank on a dodge van and the oem pump would not let flow thru. Just may have to experiment, but the intank pump is actually easy to R&R.
Old Dec 26, 2018 | 06:49 AM
adoublenickel
Thank you for the help.
dannierogg
Nov 20, 2009 04:14 PM
87ford
16
Oct 24, 2006 01:50 PM
735.0Short
31
Nov 13, 2005 10:42 PM
Southern_Bronco
Nov 24, 2004 08:13 PM
Chumbucket
Mar 31, 2004 05:02 PM
