63 f100 292 electrical
Old 12-22-2018, 10:56 AM
sre8212's Avatar
sre8212
sre8212 is offline
Brake lights, directionals work fine with key on accessory, but sometimes do not work once engine is turned over and running. Seems to happen more often if engine is cold. Usually remedied by turning truck on and off once or twice...There has been a alternator ,generator conversion, but that was sometime ago. Appreciate any ideas!
Old 12-22-2018, 01:17 PM
resonateur's Avatar
resonateur
resonateur is offline
My suspicion is a bad ignition switch. You could test the power feed to the lights from the ingnition in the “run” position with a 12v test light or meter to find out for sure.
Old 12-22-2018, 02:07 PM
unibody62's Avatar
unibody62
unibody62 is offline
X2, likely. Maybe something with the fuse box, like corroded contact or such. My 62 has the fuse block as part of the headlight switch, but I’m not sure if they changed that by 63. I hate that configuration, and when I put in new wiring, that will change.
Old 12-22-2018, 09:30 PM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab
Jeff64F100CrewCab is offline
For sure on my '64, not sure about your '63, but the turn signal and brake wiring goes through the steering column and there could be an open wire (broken) in there.
Risingphoenixtowing
06-23-2018 12:59 PM
67-F100
11-21-2012 11:53 PM
halltm
04-22-2012 10:07 AM
Okrhys
03-06-2012 10:05 PM
nayr
Electrical Systems/Wiring
12-07-2004 09:34 PM
Quick Reply: 63 f100 292 electrical
