64 f100 no brake lights
The 12v that goes to the brake switch comes from the turn signal switch. Check the connectors at the firewall and to the turn signal switch. In my case, I had corrosion at the fuse block preventing a good connection, as well as a bad turn signal switch. Get yourself a wiring diagram and trace out the wiring. Good luck.
Kurt
Kurt
It's notorious for getting gummed up with dirty brake fluid, and as soon as this occurres, the little charmer no longer works.
This same switch was used from 1940 thru 1966 on myriad FoMoCo vehicles, so it's EZ to find.
C1AZ-13480-A (replaced 01A-13480) .. Stop Lamp Switch (Motorcraft SW-24) / Available from Ford and a gazillion autoparts stores.
Redneckrucker16
07-22-2014 12:05 PM
toolman617
Electrical Systems/Wiring
08-03-2005 03:37 PM
toolman617
07-01-2005 08:20 AM
