Full Retrofit Headlights DIY
i ran resistors on my titan for my led turn signals, worked great
If i do Quads none of this will be an issue, but then i'm having to spend money lol. the prize was ONE set of retrofits.
on
1 Post
i'm worried about the low beam being completely unused in the bottom socket wiring tho...or will the resistor compensate for zero load? the pod should pull enough to where high beams shouldn't be an issue.
Heres an idea, The link below is for prewired male H13 plugs, you could solder your resister onto the leads, heat thrink the whole thing up and boom, nice and clean with no hyper flash.
https://www.amazon.com/PartsSquare-P.../dp/B00Q3UZURE
You projectors have their own harness that is going to plug into the top headlight plug. Im thinking this might be how the bottom plugs will be wired. I've never done anything like this before but I really dont see why this wouldnt work. let me know if you have any questions.
Awesome thats what i was thinking. Yea top should be all good, running a LED cube as ONLY high is the only question and i'm thinking what you just posted should do the trick. One way to find out lol. Or go full baller, get the LED lights with a backlight and hook that function to the low beam wire,,,,
on
1 Post
Full baller is always an option lol, all has to do with what your wallet will allow. My only concern would be the heat output from those resistors. I know space is limited but i'd try to put them in a well ventalated area. Im excited to see how this all turns out. Please throw all your pics up on this thread, in the case that I get a wild hair.....I'll be reffering back to this thread as I think your the first "non-professional" to try this out lol. What projectors are you thinking about throwing in there?
#28
Yea the resistor will need to be on the fender/under the hood mounted to a piece of metal. yea i'll keep everything here as theres no need to start another thread....I'm a PRO DAMN IT lol....still waiting on the retrofit source to get back to me regarding what exactly I won lol. Wild hairs get me into a lot of trouble. First it was a home built "overland" trailer, now it's headlights round 2.
#30
naw. Got both headlights opened up and the permaseal cleaned outta the channels. TheRetrofitSource.com emailed me and said late this week or probably early next week we will get what I won sorted out. At that point I hope they confirm the wiring for the LED cube in the bottom spot or else i'll see what they recommend. I wanna drop the stuff off for paint but it'll be wise to wait and get everything test fitted before paint lol. So probably nothing going on on for another 2 weeks depending on shipping.
