Injector install
Old Dec 19, 2018 | 11:22 PM
rc.chris's Avatar
rc.chris
Injector install
I’m going to stud my truck and will be pulling the injectors, should all the O-rings be replaced when reinstalled? If so, where’s best place to order them and should I use only oem?
Old Dec 19, 2018 | 11:25 PM
FiznUKa's Avatar
FiznUKa
Yes replace the orings and copper crush washers. Alliant sells a good kit. Give me a second and I’ll find the number
AP0002 is the kit.
Old Dec 19, 2018 | 11:55 PM
rc.chris's Avatar
rc.chris
Ok, thanks
Old Dec 20, 2018 | 06:59 AM
navistarnut's Avatar
navistarnut
Get the bore brushes if you want to get those bores spotless, pretty much rule of thumb you should be able to eat off the surface of a cleaned injector bore.
The little one works very nice for the crush washer surface.
https://www.xtremediesel.com/alliant...ctor-brush-kit
I think it was Sean who might have found a slightly cheaper alternative?
Old Dec 20, 2018 | 10:33 PM
SmackDaddy's Avatar
SmackDaddy
Ed at FICMRepair rented a set of Aliant bore brushes to me when I did my injectors. I see no reason to buy brushes unless you plan on swapping injectors a lot.
Old Dec 21, 2018 | 10:30 AM
Jason Cook's Avatar
Jason Cook
Yes do that!
Whenever you take out some with a o-ring always replace it! no matter what the anybody ever tells you! They are very cheap and easy to replace so the part won't leak. BTW
Old Dec 21, 2018 | 10:56 AM
SmackDaddy's Avatar
SmackDaddy
I concur! This goes for just about any part with O rings, gaskets and seals.
bismic
Apr 26, 2024 02:25 PM
HTM101
Dec 1, 2018 11:53 PM
Super Duty Service
Mar 28, 2015 09:54 PM
ddeflyer
Feb 19, 2015 12:39 PM
nookiemonster55
Oct 22, 2010 01:12 AM
