Sooooo....
Old Dec 19, 2018 | 03:51 PM
Maiden666's Avatar
Maiden666
Sooooo....
In at one of the Ford dealers here and was asking about some accessories. I asked him if they could change the TPMS values for me so I could run a lower pressure...."no, Ford let us do that until 16 and after that it won't let us change it." He then said that, (on his own) "With the Death Wobble issue, Ford is not allowing us to make a lot of changes." Me, 'I thought the TSB addressed that with some of the front end components?' "We have tried everything here and everytime it was attributed to the Goodyear Wranglers after 15000 miles. After we put Michelins on the customers vehicles, they never came back with it again. I see you don't have the Wranglers?" Me, ' I put on the Nokians for the winter, the Wranglers are in the bed". "Yeah, probably want to go with Michelins after the winter".........interesting......thoughts?
Old Dec 19, 2018 | 04:22 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Ask in the Death Wobble thread. Someone started a spreadsheet for cataloging and looking for similarities. Maybe he could add a "tire type/brand" column?
Old Dec 19, 2018 | 04:26 PM
Crabbman P's Avatar
Crabbman P
That would be an easy fix. Recall our Wranglers and give us new Michelins. But I suspect there's a bit more to it then just one brand of tires.
Old Dec 19, 2018 | 04:45 PM
Clubwagon's Avatar
Clubwagon
21K miles on my Wanglers. So far so good. I keep them rotated.
Old Dec 19, 2018 | 05:35 PM
CBEllis's Avatar
CBEllis
37k on my ford issued wranglers - no issues. Even wear, keep em rotated, quiet and smooth. I’ve been impressed really...although I wouldn’t buy them, they've been a good tire to start with.
Old Dec 19, 2018 | 05:38 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
I have Michelins and have had DW !!!!
Old Dec 19, 2018 | 05:42 PM
Alaskan_Warbird
Well there you go. This negates that theory.
Old Dec 19, 2018 | 05:57 PM
Maiden666's Avatar
Maiden666
Yeah....was not really buying it but was an interesting take...
Old Dec 19, 2018 | 07:55 PM
VA13FX4's Avatar
VA13FX4
Plus people with 37s have it too.
Old Dec 19, 2018 | 10:23 PM
64509chvl's Avatar
64509chvl
You can change the TPMS thresholds in Forscan. I changed a few things with it & it works great!
Old Dec 20, 2018 | 07:54 AM
delorenzomp's Avatar
delorenzomp
If I followed some of the posters correctly there is quite a range of tire pressures that 'are allowed' before the TPMS alarm sounds...and if I am not mistaken, the tire pressures still show on the screen for monitoring by the driver (I do not yet have my truck so cannot speak from experience)...and the pressures stated change color, I believe, when 'out of range'?...can anybody please confirm?? Thank you.
Old Dec 20, 2018 | 10:23 AM
mhoefer's Avatar
mhoefer
Yes, they change colours and alarm according tot he thresholds set using Forscan. The problem is the rears. My truck says 50psi front, 80 rear. I changed to 50/50 on the TPMS because I like to run 60 all the way around, unless loaded or towing. Even though set at 60 psi, with some driving they all go up to 65 or 67 psi wither driving. The settings are cold settings. I find for proper wear, they have to be this low or your wearing only the space tire of the tire.
41,000 km on the GY Kevlars and swapped out for new GY Duratracs. No death wobble as yet.
the new tires ride really nice, and grippy for the winter.
i think your dealer needs to do some reading on death wobble, it’s a combination of tires, alignment spec, shocks, steering damper. Any one issue and usually pretty easy to diagnose, multiple smaller issues in combination much more difficult.
Old Dec 20, 2018 | 10:45 AM
delorenzomp
thanks, mhoefer.
Buckskin-Saddlebred
Mar 10, 2013 06:37 PM
lanedecamp
6.7L Power Stroke Diesel
Nov 5, 2012 12:11 AM
landscaper62
Aug 22, 2011 09:35 PM
Spike Engineering
Dec 22, 2010 11:59 AM
K.O-T.O
2004 - 2008 F150
34
Aug 12, 2006 09:01 PM
