I believe my expedition is stuck in 4L but the light doesn’t come on at all. The other night I was 20 miles away from home and couldn’t drive because the truck wouldn’t go over 20 mph and the rpms were at about 3. The only light that will come on is the A4WD light. Is there a way to get it into 2wd so I can at least drive it back and forth to work. I don’t use the four wheel drive often. Any help would be appreciated
You may need to get under the truck, remove the shift motor and with a wrench turn the shaft back to the 2wd position. If it doesn't want to move you may need to jack up a couple of tires to unload the drivetrain.
