Flywheel bead blast
Old Dec 18, 2018 | 01:33 PM
daveengelson's Avatar
daveengelson
Flywheel bead blast
In the process of replacing clutch assembly in 65 F100 with the 302. I had the flywheel turned 3 weeks ago and with seasonal whether the flywheel looks fairly crusty with a layer of surface rust. Before installing wonder if I should use sandpaper, wire wheel, or blasting cabinet using glass bead to clean the surface, or would it be best to leave well enough alone?>
Comment/suggestions appreciated!
Old Dec 18, 2018 | 01:36 PM
ford390gashog's Avatar
ford390gashog
The only thing you should be using is acetone to clean it. Everything else you mentioned should never be done to a surface that was machined flat.
Old Dec 18, 2018 | 04:42 PM
daveengelson
I thank you for the input, acetone it is!.
daveengelson
Jan 9, 2019 04:37 PM
champers
Aug 22, 2010 10:47 PM
Ryan50hrl
Jul 17, 2002 10:44 AM
lee
Apr 30, 2002 02:22 AM
