1979 tailgate adjustment?
Old Dec 17, 2018 | 09:23 PM
Cougar2's Avatar
Cougar2
There doesn't seem to be much info on the 73 to 79 tailgate latch and tailgate adjustments. Mine has to be slammed with the latch handle pulled out and it still doesn't latch most of the time. It there any info on how to get the tailgates working well on the 73 to 79 trucks?
Old Dec 17, 2018 | 10:17 PM
crownver's Avatar
crownver
There is in/out adjustment on the latch on the gate itself, and the striker on the box has vertical adjustment. There is supposed to be a rubber bumper on the part of the box that the gate shuts on to stop it rattling.
Old Dec 17, 2018 | 10:26 PM
Cougar2's Avatar
Cougar2
I put new rubber bumper/dampers on that most to the box. The brackets them selves need adjustment, I will check to see if they need to be moved. I thought there would have been adjustments inside the tailgate.
Old Dec 17, 2018 | 10:36 PM
crownver's Avatar
crownver
The adjustment is on the latch on the tailgate. 3 bolts on either end I think.
Old Dec 18, 2018 | 04:12 AM
hail destroyer's Avatar
hail destroyer
Don't fear the hammer. My bed was slightly tweaked from years of abuse. When I restored it (patch panels, welding, straightening dents, etc) the whole thing was ever so slightly off. When I reinstalled the tailgate, it wouldn't close right, no matter how much I messed with adjustments........ eventually I put a small pry bar in the upper lockink tab on the "tight" side and gave it a few sharp tabs with a ball peen hammer. Bent the tab about 1/4 inch and everything aligned up beautifully. Also, a dab of grease on the strap hinges and striker points makes a world of difference.
Old Dec 18, 2018 | 01:05 PM
Aaron-71's Avatar
Aaron-71
I recently disassembled my tailgate on my 1979 F250 thinking that the adjustments had something to do with the mechanisms inside the gate itself. I was wrong.
All of the adjustments happen along the edge of the bed between the space where the tailgate goes. Be prepared by having some penetrating lubricant and some heat available to break loose stuck bolts.
It will take a lot of patience, but there's a surprisingly large amount of adjustment available on these old truck tailgates.
Old Dec 18, 2018 | 02:38 PM
Cougar2's Avatar
Cougar2
Thanks Aaron, good to know, I originally thought it was all internal as well. I will be doing adjustments soon, so this info is just in time.
Old Dec 18, 2018 | 02:40 PM
Cougar2's Avatar
Cougar2
Thanks for that info, I will look at that part of the latch and I don't have a problem with using a bigger hammer if need.
Old Dec 18, 2018 | 03:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Dec 18, 2018 | 07:53 PM
Cougar2's Avatar
Cougar2
Thanks for the diagram, really shows how simple this setup is.
rob17
6.7L Power Stroke Diesel
Aug 27, 2016 07:01 PM
Kurtboyd
Sep 13, 2015 05:02 AM
1997fordf350
Jun 25, 2013 07:04 PM
stephenw
Feb 16, 2003 07:05 PM
