Massive electrical issue, had this before?
Old Dec 15, 2018 | 01:28 PM
banoness's Avatar
banoness
Hi all,
Been struggling with an electrical issue with my 79 F150 302 autoC4. Here is the concern:
Hard or extended crank on cold and hot start. Then when running, all major electrical systems run at a reduced speed or cut out all together. Lights flicker, HVAC cuts off or blows low on high, wipers go super slow, no radio, temp gauge bounces all over the place as does the fuel gauge, etc. The alternator gauge reads normal while running and is probably about 8 years old but could be bad, may test that today. The neutral safety switch is probably bad as I need to start in neutral often, but was fine before this concern began. My thought is that a body ground is off or cut somewhere. Here is the current service history to help eliminate the obvious:
Brand new within last 3 months:
battery (700 CCA) (today)
battery cables and terminals
starter
starter solenoid
plugs, wires, cap, rotor
ign coil
ign switch
ign box
fuse box passes visual inspection for burns
Motor has 40K on it and has all new service parts around it, belts, hoses, carb, etc.
I have owned the truck for 20 years, dash has never been out of it.
Thanks all for your help on old blue.
Old Dec 15, 2018 | 01:54 PM
march's Avatar
march
Voltage regulator?
Old Dec 15, 2018 | 01:55 PM
banoness's Avatar
banoness
Also new...
Old Dec 15, 2018 | 03:49 PM
'79BabyBlue's Avatar
'79BabyBlue
Loose, worn, malfunctioning battery cable connector? I'm betting negative. Ford's do weird **** without correct juice.
Correction...Ford's do weird **** just cause they can.
Old Dec 15, 2018 | 05:23 PM
Shawner1974's Avatar
Shawner1974
Had a similar issue on my 78. Check your grounds first. I ended up adding a ground from battery negative to the inner fenderwell. The ground from battery to engine was ok. Then I added a ground from engine to frame . Cured all my ills, including flickering lights, radio cutting out, blower motor drawing down. Ran better to boot! Before this I had already replaced headlight switch, dimmer, put in headlight relay. It was only after I added an aftermarket voltmeter that I could see what was happening. Every time I hit a bump, the voltage would drop to 9! After I added my grounds, I had 14.5 volts and it doesn't vary vary much.
Old Dec 15, 2018 | 06:17 PM
banoness's Avatar
banoness
That's exactly what Im goin to do first thing tomorrow, thank you.
Old Dec 15, 2018 | 06:31 PM
Shawner1974
Good luck! Like '79BabyBlue said, Ford's can do weird stuff if the grounds aren't 100% .
Old Dec 15, 2018 | 06:46 PM
banoness's Avatar
banoness
Yes, it has to be a ground issue. Thanks everyone.
Old Dec 15, 2018 | 07:15 PM
butcher7788's Avatar
butcher7788
You can never have enough grounds on old Fords. Or enough good stainless star washers that'll really bite into paint, undercoating and rust to find clean metal.
Old Dec 16, 2018 | 08:51 AM
JRT812's Avatar
JRT812
You wouldn’t happen to have any pictures of the set up would you? Probably a stupid question, but do you remember what gauge wire that used?
Old Dec 16, 2018 | 10:20 AM
banoness's Avatar
banoness
I figured out the issue, when I put the new battery terminals on, it didn't have the additional ground lead from the neg terminal to the body. It is amazing how much a bad ground can cause so many issues!
Old Dec 16, 2018 | 10:41 AM
beartracks's Avatar
beartracks
Belt and suspenders! I have ground from the battery to the frame, fender and engine. Also engine to firewall.
Old Dec 16, 2018 | 11:31 AM
butcher7788
I got battery to engine, battery to fender, engine to cab, cab to hood, cab to frame and cab n frame to bed. Prolly overkill but everything is working. I get really nice stainless braided ground straps through work so might as well splurge.
Old Dec 16, 2018 | 03:30 PM
Shawner1974
You got it fixed before I could respond lol. Good job!
Ddaybc
Oct 12, 2018 09:20 AM
Austin W
34
Nov 10, 2017 09:51 AM
Scott Yager
May 2, 2016 08:04 AM
straightsixer88
26
Aug 29, 2015 05:31 PM
jasindude1
Sep 19, 2014 06:02 PM
