360 Freeze plug
Old Dec 15, 2018 | 08:26 AM
MtnDweller's Avatar
MtnDweller
360 Freeze plug
So While flushing the coolant system in Ole Gael I found that a freeze plug was leaking. A little further investigation is that it has a hole in from rusting through. I have been trying to figure out how to replace it without removing the motor so I supported the engine and removed the motor mount that is in the way and was thinking that I could knock out the old one. But that seems to much more difficult than I anticipated.
Anyone know any tricks?
Old Dec 15, 2018 | 10:42 AM
kenny nunez's Avatar
kenny nunez
Freeze/core plug
The correct size of the plug is 2 & 49/64”. They can be really hard to install. I must say that particular job was the one I hated the most working at my Dad’s shop. There is a rubber expander plug which may get you running again. Just be sure that the hole is clean and dry and do not use any sealant otherwise the plug will not stay in. When you knock out the old plug get ready to get pelted with the casting mud that is in the cooling jacket. Try to hose out as much as possible. Good luck
Old Dec 15, 2018 | 11:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by kenny nunez
The correct size of the plug is 2 & 49/64."
FE freeze plugs are 1.75" O.D.
Old Dec 15, 2018 | 05:05 PM
MtnDweller's Avatar
MtnDweller
yep. Worked out well.
It was easier than I thought it’d be. Just punched it in on one side and it spun so I could grab it with some pliers.
Then used a socket and hammer to press the new one back in.
Old Dec 16, 2018 | 04:33 AM
GaryKip's Avatar
GaryKip
Good job! I bought a set of brass ones, I'll have to do them this winter, before I put the headers on.
Old Dec 16, 2018 | 10:35 AM
kenny nunez
Red face Freeze/core plugs
I have used 2 3/4” core plugs many times and just last night at our Ford club’s party, one of our members is a engine rebuilder. He also uses the 2 3/4” plugs.
There is a new publication # sa352 Workbech How-to by Barry Rabotnick on the FE and how to rebuild them. He claims that the 2 49/64” is the correct size. I realize that this is “splitting hairs” but it would be interesting to know which is the correct plug.
I am sure that pounding in the larger plug while the engine is on a stand is not too hard. So the smaller is easier to install from underneath with a drop light burning your arm and water dripping in your face while the creeper is moving too much or stuck against the jack stand and at the same time making comments about the parentage of the vehicle you are under adds to the fun because you just hit your hand with the hammer.
Old Dec 16, 2018 | 11:16 AM
MtnDweller's Avatar
MtnDweller
I'm not real sure which is official but I do know that Napa gives you a 2-3/4 in a freeze plug kit for a 72 Ford 360 and it went in without leaking.
Old Dec 16, 2018 | 01:05 PM
NumberDummy
How can a 2 3/4" core plug replace a 1 3/4" (1.75") core plug?
Pic: See C8AZ-6026-A
Old Dec 16, 2018 | 03:27 PM
Tedster9's Avatar
Tedster9
...easier to install from underneath with a drop light burning your arm and water dripping in your face while the creeper is moving too much or stuck against the jack stand and at the same time making comments about the parentage of the vehicle you are under adds to the fun because you just hit your hand with the hammer.
LOL ain't it fun
Old Dec 16, 2018 | 08:03 PM
MtnDweller's Avatar
MtnDweller
😳 1-3/4 is what I meant to say.
jmsmith76
Jun 16, 2013 03:19 PM
rockslut
Mar 7, 2006 11:26 PM
Seifferlein
Aug 17, 2004 11:48 PM
62stepside
Apr 9, 2003 08:01 AM
mobleyt
Jul 22, 2002 01:33 PM
