Used camper top compatibility
Old Dec 14, 2018 | 01:33 PM
EKnieper's Avatar
EKnieper
Does anyone have any idea how close the fit would be for a camper shell from an ‘04 super duty to a ‘17 with the same bad length? I know the rear glass will not go outside of the tailgate. More wondering if the cab height and front of the topper will line up with the truck very well. I have a friend that will sell me one for $100 but I have to drive an hour to see if it fits at all. I wouldn’t have it in all the time but mostly for hunting and ice fishing trips.
Old Dec 14, 2018 | 01:45 PM
ford390gashog's Avatar
ford390gashog
There is a better chance of it fitting a golf cart. There is zero dimension that is the same. Bed rails are higher, bed rails are wider and tailgate cap is much wider.
Old Dec 14, 2018 | 04:39 PM
EKnieper's Avatar
EKnieper
I figured that would be the most likely case. I have read that most caps would work from 99-16 with minimal issues other than the tailgate shape. I haven’t been able to find anything on how different the ‘17s are from the ‘16 models though. I can’t come off the $$$ for a new cap that I don’t need more than a few times a year.
Old Dec 14, 2018 | 06:05 PM
broncorif's Avatar
broncorif
I recently found a top on Craigslist that was listed for a Ford F-250 up to 2016, but it was on a 2017. The gentleman confirmed it was an older model top that he used temporarily. He indicated that it wasn’t a perfect fit, but worked for his needs. I chose not to buy it because I’d want a perfect fit. Not sure if that helps, but figured I’d share.
Rob Alexander
2015 - 2020 F150
Jan 10, 2018 05:56 PM
JacobD
Jan 8, 2018 03:24 PM
BigDaddy2518
2009 - 2014 F150
Feb 20, 2017 09:39 AM
BigDaddy2518
Feb 18, 2017 08:55 PM
rayw72
Oct 16, 2015 02:09 PM
