7.3 glow plug relay
7.3 glow plug relay
Hi guys,
I have just converted my 6.9 to the 7.3 glow plugs, zd9 beru all new, new glow plug relay and the wts light does not work. if I send a 12 volts to the wire for the wts light going from the relay to the dashboard, it lights up, so the bulb is good. I have two glow plug relays and neither triggers the wts light, I was just thinking if the relay actually triggers the ground for the wts to light up, as there is nothing comming off the blue wire on the relay. Brand new NAPA echlin relay. Also the relay starts clicking after good 15+ seconds with ambient temp 25-30 F.
Any help appreciated.
Thanks.
Thanks.
Received 3,118 Likes
on
i have never trusted the WTS light. i run my own light hooked to the output of the relay going to the glow plugs.
on the older trucks it was a small 12 volt light bulb, but i have since converted all the trucks to a small led bulb.
if the light is on, the glow plugs are getting power.
so what i do is wait for the light to go from solid to flickering, then start. pretty much the same as the WTS light works, except the WTS light does not flicker when the relay cycles.
Steelheader87
20
10-15-2016 07:29 AM
whiteboyslo
03-03-2012 08:40 PM
