Gp double check me please
Old Dec 8, 2018 | 09:59 AM
beersy50's Avatar
beersy50
This season my plow truck wouldn’t start, first time it’s failed me sense I installed new injectors, pump, return lines, and (beru) glow plugs.
I re-read the glowplug thread above and tested my glow plugs. How ever I didn’t have a chance to run down and unplug the block heater. So the engine wasn’t ice cold. On the left bank starting from the front I had .2, 1.1, 1.0,1.1 ohms. On the right bank I couldn’t get the second and the fourth plug but #1 was 0.0 and so was #3. So if my tests are right I need at least the whole right bank and the first on the left? I’ll probably get all 8 any way. Where is the best place to get the beru plugs? It was probably 5-6 years ago when I did them before and can’t remember where I got them.
Old Dec 8, 2018 | 11:39 AM
Etone's Avatar
Etone
Just do an internet search for whatever you want if you want to order online. I usually call a couple local auto parts stores and see where I can get them right away. Also read "glow plugs 101" posted by chevyeater. The test light method has never failed me.
Old Dec 8, 2018 | 01:04 PM
norm805's Avatar
norm805
I found a great deal on eBay
Old Dec 8, 2018 | 03:51 PM
beersy50's Avatar
beersy50
Does anyone remember the beru part number?
Old Dec 8, 2018 | 03:56 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
If it's not a Beru,it will not do.
It sure beats pulling the heads and you know it too.
If you use an off brand plug,it would surely be a shame.
However,you will only have yourself to blame.
If it didn't come packaged by Motorcraft,your engine will make a boat anchor for your raft.
If your wise,you'll know it's to be made in Germany and accept a socket,3/8 in size.
If it takes a 10 millimeter instead,you will wish that the previous owner of your truck was dead.
Depending on the year,install a ZD1A or a ZD9 and you'll rest easy,knowing everything will be fine.
Heed the advice by the wise,or it could lead to your engines demise.
For if it's not a Beru,it will not do.
Old Dec 9, 2018 | 08:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
your 89 7.3 will use Motorcraft/Beru ZD-9 glow plugs.
Old Dec 9, 2018 | 11:54 AM
Dieselamour's Avatar
Dieselamour
Not naughty, but very nice advice, you will see. Thanks to Ford Forums and FORDF250HDXLT
In for the day. 1292018
Old Dec 10, 2018 | 06:00 PM
ihateminimumwage's Avatar
ihateminimumwage
I've always found the best deal through RockAuto, currently $9.86 each.
Old Dec 12, 2018 | 06:00 PM
norm805's Avatar
norm805
Beru zd-9 on eBay $71.99 delivered
Old Dec 14, 2018 | 01:24 PM
cadunkle's Avatar
cadunkle
I just replaced the right side bank on mine today, 3 were failed reading 35-85 ohms. The good one on that side and 3 on the other side are around .75 ohms. Last one (hard to access, under turbo, fuel plumbiong, and sending units) I didn't check. Maybe that one is bad too. Cold starts the past week have been really rough and smokey.
So 3, maybe 4 failed Motorcraft (Beru) ZD-1A. All were new when I installed this engine in June or July. I replaced the right side with DieselRX out of my old 6.9 that blew a head gasket, those plugs are at least 5 years old (I've had the truck that long) and never had a problem with them. To the credit of Motorcraft/Beru none were swollen, the Autolite plugs I pulled out of the 7.3 before I rebuilt it were all swollen to varying degrees, though all came out intact with a little lubricant and patience. Regardless, I'll stick with DieselRX plugs since they have worked great for me over the long term.
dn29626
Jan 24, 2019 08:00 AM
henslee
Oct 27, 2012 11:05 PM
FionaFarmer
15
Nov 18, 2011 06:39 PM
skittlejr
15
Jan 20, 2008 04:54 PM
redmt77
Jan 18, 2005 12:04 AM
