Gas mileage decreasing
Old Sep 27, 2003 | 05:22 PM
slant7's Avatar
slant7
I have a 2001 Excursion PSD and would like to get some help.
I have changes all the filters, oil, and kept it well maintained. The last three months my gas mileage has dropped from 17.0 mpg to 16.3 miles per gal with no change in the way I drive the vehicle.
I don't want to put a chip in it because I don't want to void the warranty.
Any suggestions has to why it would go down hill so fast.
I have 48000 miles on the truck and it is completely stock.
Thanks
Slant 7
Wickenburg Arizona
70 miles Northwest of Phoenix Arizona
Old Sep 27, 2003 | 07:06 PM
theologian's Avatar
theologian
One reason Fuel mileage goes down on a psd is dirty oil, or bad fuel filter. Blocked or dirty air intake will also cause bad fuel mileage..
have you drained the water separator recently - if not you could have gunk in there that is causing you fuel mileage to drop.
(PSD do not have gas mileage... )
Theo
Old Sep 27, 2003 | 07:10 PM
slant7's Avatar
slant7
I change the oil every 4000 miles and just changed the fuel filter and air filter. Not sure where the fuel separator is though.
Slant7
Old Sep 27, 2003 | 09:00 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The mileage varies from time to time with driving conditions. Unless it's been like this, I wouldn't worry too much if it dropped 1-2 mpg. Have you run a fuel additive through a full tank yet? You probably have dirty fuel injectiors. I have a 2001 like you do and the mileage was dropping on mine too. I ran some of Power Service's Diesel Kleen and my mileage started to get better. It also gave me a little more power overall, it was just like the day I drove it off the lot. Power Service's Diesel Kleen comes in a silver bottle and treats 2 tankfuls per bottle. I use it whenever I fill up and since then, my mileage has jumped up a few points. Diesel Kleen is the "summer formula" of Power Service's fuel additives. It's about $3-$5 per bottle at wal-mart. If you live up north where it gets cold, use Stanadyne. It's hard to find, but it's worth using if you can. If you can't find it, use Power Service's "Diesel Fuel" (the white bottle) Both these additives have an anti-gelling agent to prevent your diesel from freezing or gelling in your tank and fuel line. Try that and see if it gets you back up to 17mpg.
Old Sep 27, 2003 | 10:48 PM
slant7's Avatar
slant7
I will try that this week.
THANK YOU!!
I live close to Phoenix Arizona, I do not have to worry about freezing fuel.
Slant7
Old Sep 28, 2003 | 03:54 PM
Toreador_Diesel
Just out of sheer curiosity, what color is your X? Limited? XLT? 2-wheel drive? 4-wheel drive?
Old Sep 30, 2003 | 05:48 PM
slant7's Avatar
slant7
2001 XLT 4X4
mebe2k
6.7L Power Stroke Diesel
Feb 27, 2021 08:18 PM
ChuckRob
Apr 2, 2013 12:03 PM
JB78f150
Oct 27, 2011 02:55 PM
Cowboy Brett
May 27, 2004 08:27 AM
slant7
Sep 30, 2003 05:56 PM
