Understand Freeze Frame Data
Old Dec 9, 2018 | 11:16 AM
TaylorKelsey's Avatar
TaylorKelsey
Could someone analyze my freeze frame data as to I don’t lnow what I’m looking at.
Having problems with my 05 f150 xlt with 187,000 miles stumbling around 40 -55 mph.
No codes are showing up.
So maybe someone could look at my data and see if anything looks out ordinary.
Thanks
Fuelsys1 CL
fuelsys 2 n/a
load pct 41.6
etc *f 178
shrtft1% -1.6
longft1%10.9
shrtft2 % 3.9
longft2 % -7.8
rpm min 872
vss mph 7
spardadv 19
iat *f 68
Maf lb/min 1.569
tp% 15.7
o2b1s1 v 0.810
shftftrb1s1 % -1.6
o2b1s2 v 0.080
02b3s1 v 0.795
shrtfrtb3s1 % 3.9
02b3s2 v 0.085
runtm 15
frp psi 39.4
fli % 10.2
warm up 0
evap vp in h20 -0.103
baro 27.5
catemp11 965.12
catemp21 965.12
vpwr 14.322
abs 27.1
eq rat 0.999
plase if some one could shed some light on to what this means . I understand some like th cat temp and few other things but other than that I’m lost.
Thx for any help.
Old Dec 9, 2018 | 04:07 PM
steve(ill)'s Avatar
steve(ill)
someone can tell you a lot more than me, but the 5-6-7-8 readings are Short term fuel trim ( bank 1 or 2) and long term fuel trim ( bank 1 or 2)... what I see is the long term trim on one side is 10.9% while the other side is -7.8% ........ these are not excessive, but not similar values. I think a positive value leads one to believe that an injector is plugged so the computer is trying to put in extra fuel to compensate... I think a negative number means the injectors is leaking so the computer is trying to compensate by cutting back on the fuel. Depending how you drive, I would think both sides would be somewhat negative, or both would be somewhat positive. Since they are opposites, I think it might be saying you have a sticky or leaking injector on one side. Are the injectors original ? Is this a 4.6 or 5.4 ?
Old Dec 9, 2018 | 08:19 PM
TaylorKelsey
I’m assuming the injector are factory as I’ve only had the truck for 7 months.
5.4 engine.
Old Dec 9, 2018 | 11:16 PM
F150Torqued's Avatar
F150Torqued
https://www.ford-trucks.com/forums/1...l#post18351548
steve(ill)
2004 - 2008 F150
Jun 16, 2016 10:22 PM
Shorebreak
May 14, 2015 06:52 PM
Fordmom530
Modular V8 (4.6L, 5.4L)
Mar 22, 2015 08:30 PM
robbyk85
1997 - 2003 F150
Mar 5, 2011 01:42 AM
DeenHylton
Apr 6, 2002 09:53 PM
