What is this
Old Dec 10, 2018 | 07:21 AM
TooManyToys.'s Avatar
TooManyToys.
Using the search function of the forum gets 500 threads about fuel pressure installs. To search you do this .... to get something like ...
A good thread
https://www.ford-trucks.com/forums/1...ch-folder.html
It is located in the tech folder at the top of the section.
Old Dec 10, 2018 | 08:34 AM
87crewdually's Avatar
87crewdually
Originally Posted by 87crewdually
IF you take a shortcut and go straight to the algaecide make sure you carry atleast 3 sets of filters and the tools to change them. While you're at it carry a catch pan, gloves, and something to lay on. I'd also monitor fuel pressure but that's easy for me to say since I already have a gauge for that.
CMG66999, There's options such as Isspro out there for gauges but I took the economical approach and I've been happy. I've been running this setup for some years. I also bought an additional sensor and harness kit to monitor the coolant pressure on occasion. I got everything from Glowshift, use code GREEN15 for 15% off.
Heres some links.
Single POD
GAUGES
Adapter
SENSOR ISOLATION KIT
^^ Don't be alarmed, the gauge is displaying coolant pressure. Fuel pressure is usually 65 p.s.i.
Old Dec 10, 2018 | 08:38 AM
kgburns's Avatar
kgburns
Lots of gauges available, just be sure and order the fuel pressure adapter fitting for your filter bowl.
Old Dec 10, 2018 | 09:23 AM
seijirou's Avatar
seijirou
But don't read your fuel pressure from the degas bottle.
Old Dec 11, 2018 | 07:18 PM
Cmg66999's Avatar
Cmg66999
Trailering
87crewdually I was on Glowshifts site this morning. I was quite impress with there site. The only thing about there videos are thought you are to install EGT probe on the passenger side not driverside. Just trying to figure which gauges to get besides fuel pressure. I want to get a tuner also.
TooManyToys thanks for the lesson on how to use the search bar.
Old Dec 11, 2018 | 07:20 PM
87crewdually
Duplicate post
Old Dec 11, 2018 | 07:25 PM
87crewdually
EGT probe is installed laying on your back, looking straight up at the #8 port on the driverside manifold. Plenty of room and the chips fall down, not in the manifold.
Old Dec 14, 2018 | 07:14 AM
Cmg66999's Avatar
Cmg66999
Trailering
Thanks, easy enough
Old Dec 14, 2018 | 07:16 AM
seijirou's Avatar
seijirou
Put grease on the drill bit and tap too, helps keep it that much cleaner in the manifold.
nathanr561
Aug 3, 2019 05:18 PM
Carbonarc
Apr 15, 2018 07:25 PM
white Buffalo
90
Oct 27, 2015 04:01 PM
rideracelivemx7
19
Feb 24, 2011 06:44 PM
motocaptain
Aug 7, 2008 11:42 AM
