Door Latching Issues
Old Dec 10, 2018 | 03:00 PM
Zchludil's Avatar
Zchludil
Originally Posted by NotJustaTruck
My truck is at dealership being "fixed" a
second time
18N03 failed to fix it . They are now replacing door latch regulator assembly
As it's a newly designed one piece setup
Will find out this week if it works
Took my truck to the dealership this morning and informed them that 18 N03 did nothing to fix my freezing door latches. The general manager had the parts guy look up the latches and claimed that there is an updated part number for the latches so they are going to try that.
Old Dec 10, 2018 | 03:31 PM
delorenzomp's Avatar
delorenzomp
...so, another day-or-so without your truck and it may be the 'fix'...have they said anything about there being a design flaw or a manufacturing flaw with the latches or is it all about moisture and water coming in contact with good latches (and the redesigned latch better isolates the latch from moisture and water...)
Old Dec 10, 2018 | 06:42 PM
HRTKD's Avatar
HRTKD
Dealer called and mine will be done tomorrow. So the parts must have come in.
Old Dec 10, 2018 | 07:00 PM
DRKBC's Avatar
DRKBC
Originally Posted by Redrockerstl55
Is there an actual recall on this latch freezing issue? I thought the Field Service Action was the only item related to this major problem. If you have a recall number please share...I'm having my truck looked at last week.
Thank you.
It just an FSA, it looked like a recall to me as when the FSA comes up on my Ford App it then goes on to explain what a recall is. But when I looked into it further in order for it to be a recall one of the following letters: S,R,E or C would be included within the code. This one has an "N" in the code (Field Service Action Number: 18N03) which means:
(N) Warranty Extension (Single Repair)
  • Extension of the vehicle's warranty coverage time and/or distance for certain components
  • Allows a one-time repair of a covered component if required.
That said, I really think it should be safety recall.
Old Dec 10, 2018 | 07:04 PM
VA13FX4's Avatar
VA13FX4
I agree. I think if more of these trucks were sold/operated in cold weather this would have more visibility. Or maybe more people reporting the issue to their dealers. Or maybe Ford just needs more accidents before they take more action.
Old Dec 10, 2018 | 07:11 PM
6.2caribou's Avatar
6.2caribou
Once the work has been done on your truck, would you be kind enough to post the part #s for the updated latches...providing that your paperwork lists them?
Thanks in advance.
Old Dec 10, 2018 | 07:19 PM
delorenzomp
DRKBC, what you shared, ‘N’ for a one-time fix, would make sense if Ford had a solid handle on the problem and on the solution, from what I am reading, they have neither, it appears that they are guessing, hoping to stumble upon a solution or hoping that we give up due to frustration.
Old Dec 10, 2018 | 10:00 PM
Mixerman90's Avatar
Mixerman90
I had the official recall fix done on mine about a month ago. Since then we've had a cold snap and the doors wouldn't latch closed after they had been opened. It's going in later this week to have it "fixed" again. They're also looking into the tailgate dropping by itself issue, as mine dropped twice the other day, once while backing up to my trailer (weird to see the camera slowly pan to the ground), and the second time as I was towing the trailer. Didn't know it until I made a turn and heard a "crunch". The tailgate broke the plastic cover on the trailers power jack.
Old Dec 10, 2018 | 11:24 PM
DRKBC's Avatar
DRKBC
No your quite right, I can't see how Ford could really hope to have that "one-time fix" plan work out, and it sounds like others here are getting the locks fixed again if the FSA fix doesn't work. I think Ford realizes it is a serious problem they need to rectify.The truck can auto start, remember your last temperature setting, move the seats, steering wheel and pedals to just the right spot, massage your butt, tell you if you crossed the center line and auto high beam your next door neighbor on the way home … you just can shut the damn doors is all.
Old Dec 11, 2018 | 02:03 AM
delorenzomp
This is an issue that, on-and-off, has occurred for decades, throughout the history of the modern automobile, perhaps never affecting an entire product lime... but this appears to be particular to an entire product line ( forget the number after the ‘F’, it is the same shared cab) ... probably some genius messed with a solid design to save $2 per latch x 800,000 vehicles annually and wham!, Ford just ‘$aved’ million$ but for the cost of their reputation and possibly sales...many of us are ‘Ford guys’, when it comes time for a new truck it’s a matter of ‘which trim package and color’ of our favorite Ford, but there are those who shop across the range of offerings from the five-or-so brands...I find it hard to believe that Ford would take a captivated repeat customer for granted, but maybe that is occurring...by the way, meant to ask, is Ford proviving loaner vehicles for these overnight inconveniences?? ...bad enough once, but when any of the ‘fixes’ fails again, that’s the time for Ford to be practicing some real damage control...
Old Dec 11, 2018 | 06:56 AM
NotJustaTruck's Avatar
NotJustaTruck
Well, I had the latch assembly replaced yesterday and the temps last night were in the high teens low twenties- 21deg. when I went out to start truck.
The door successfully latched! Handle feels "different" - more engaged if that makes sense. Have to wait and see if it keeps on working or if my passenger door (super cab) starts to act up. I think the newly designed (for this generation f-series) door latch and regulator assembly is the issue- something in the design is obviously flawed, what it has to do with colder temps. I'm not sure. Even more interesting to me is that in the first year of use I never had an issue, so repeated use must over-stress whatever is flawed in the design, but, then how or why do some have the issue immediately after purchasing a truck? They must have really went cheap on the latch hardware and it does make me question the overall integrity of the build of the truck- especially when you hear of what's occurring with "Death Wobble" Are these computer/robot assembly lines really saving any money? At what cost? Customer loyalty ?? I'm on the fence right now. I'm a "Ford Guy" and have had many F-150's/rangers/Broncos through the years and I was hoping this current truck would be one to hold onto for many years but I honestly don't know if I will or not. I was happy Ford did not take the government bailout money but it seems that they made up for it by going cheap on their trucks- hmmm.
Old Dec 11, 2018 | 09:55 AM
Capt. Ted's Avatar
Capt. Ted
I have a 2017 F350 CC and a couple weeks ago the drivers door would not latch. Slamming the door did not help. To me it seemed as though it was a computer glitch. I repeatedly locked and unlocked doors with the remote, turned engine off, and re-started. I held the door shut while I drove down to my neighbors house and turned around. Then, as if magic, on a restart it worked fine.
I had no issues last year, and no issues in the past week, even though it is now considerably colder.
Yesterday received my letter with the 18N03 notice. I'll take my truck in next week.
hail destroyer
Mar 15, 2019 11:55 PM
charles adams
Feb 21, 2019 03:25 PM
Slorigami7
Oct 31, 2018 02:31 PM
DevilDocTater
Dec 5, 2011 08:51 AM
