Fuel Pump Problem
Old Dec 8, 2018 | 11:18 PM
Jason185512's Avatar
Jason185512
Fuel Pump Problem
I have a 1994 Ford F-150 with a 5.8w. I can hear the fuel pump come on and it will start for a little while but then it eventually cuts off and the fuel pump won't come back on. I've checked ALL fuses and relays at least twice now and I can't seem to find the problem. If anyone has had this problem and figured it out please let me know. Thanks, Jason.
Old Dec 9, 2018 | 07:55 AM
subford's Avatar
subford
Ground pin #6 of the self-test connector and see if it does the same thing.
If so maybe a bad Ignition switch.
If not try changing the Fuel Pump relay with the Horn relay.
Note if the engine is not running or cranking the fuel pump will only run for one second and quit and not come back on until you turn off the key.
Self-test connector:
Attachment 277922
vance
Jul 27, 2009 08:53 AM
1 good old boy
1997 - 2003 F150
Apr 17, 2006 07:41 PM
exoldstar86it
Dec 29, 2005 06:35 PM
tom yuenkel
Dec 14, 2005 09:43 PM
jake93f150
Jun 29, 2004 08:44 PM
