HELP ENGINE SHUDDER BETWEEN 40-55mph low rpm
No not really. It's a little tricky to get ALL the injectors to come loose at manifold and not leave some that came loose at the rail.
Sorry I can't be more help on your screens --- but I am 'totally' ignorant on the AutoLink.
I know the '$' tells you that the number is represented in "Hexadecimal". Mode $06 uses hex to identify Test Id's and Monitor Id's (usually the first set of numbers) and 'Completion Ids' (usually the second set).
But I can find no TEST ID $00 or MONITOR ID $00. The heading indicates MisFire by Cyl Data --- but all them are from 50 through 56 ???
The screen prompts, I guess mean "MEASURE" (WHICH 0 WOULD BE GOOD), AND MINIMUM, MAXIMUM (for determining failure), but I do not understand what "STS" would be for.
The Cyl.4 Data shows $00 $A5 ??? There is a Monitor Id of A2 through AD. And that corresponds to the Monitor tests for Cyl 1 through Cyl 12. Thus $A5 would be Cylinder #4, but there are four COMPLETION ID's for each Monitor Test (Two counts, and Two percent) - neither would make sense at -32464. ((Which interestingly is 8130 if viewed as a HEX word number)) But even this makes no sense to the Mode 06 documentation.
Sorry - I would have to refer you to the manual for the device.
The purpose of the carb cleaner is to sneak past the plug threads during the time you are jostling
While you are jostling plug back and forth an eight of a turn, that tries to dissolve carbon around tip that seizes plug. It is good to clean all that carbon out as it breaks plugs going in and out .
Injectors not hard to pull .Pull battery negative and wait a long while for fuel pressure to drop out . Re-seat with new motor oil on orings . Clean out wells real good , keep rags in holes so you don't drop anything in there.
You can clean injector while they are out after your test see youtube videos . But it does not fix a mech bad injector or a future mech problem . They work very hard and 05's are known problem type .They are sort of expensive but do not use remans . New ones should come with new orings . You will see how simple it all is during this little foray.
I too can't decipher your scan tool , but I can barely read torque pro which is an 5$ app on android phone with a cheap blue tooth reader from amazon . Not that it s better but its familiar to most of us --but yes we think its better . You have been talking to the Guru --F150t --you are in good hands .
What NOW.
Well guys drove truck eager to investigate what u plan my attack. Truck did same thing as always buck misfire all the way home. As always I hook up scanner just to see if codes come up and sure enough .
P0430 catalyst deficiency below threshold bank2z
I had my cats checked and they are good. Is it time for o2 sensor.
Is the misfire o2 related. Or is something else causing it to throw codes. I need someone to speak simple terms. What step to diagnose what and how so forth.
Mom ready to put this skip/misfire to bed. 😡
O2 does not cause misfire ,misfires cause cat fail and O2 problems
Nothing can be analyzed well before a really good plug job its just to muddled . Its your baseline . Usually Baby cries because diaper wet It doesn't just cry and wet diaper . What the hell do I know at 73 no babies here now.
Jolly Roger Joe
Jun 12, 2018 07:58 AM
RYanokJr
Modular V8 (4.6L, 5.4L)
Dec 18, 2017 02:03 PM
