New here and hope I put this in the right place. My van drove me crazy forever with the od light flashing and jumping in and out of gear. I researched it everywhere and changed lot of parts before finally fixing it. It is a very command problem on these and no one seem to know what it was causing the problem. I changed all wheel sensors no luck, pulled code for block sensor in trans and that seemed to fix it for awhile, then started again. Changed anti lock brake module and that stopped the anti lock brk light staying on.But it wouldn't pull a code after that to tell me why od light flashed and jumped in and out of gear. Then finally found a post about the throttle body sensor causing shift problems and that it controlled voltage to brain box letting it know what gear to stay in and that rang a bell for me. I changed it and on Ford you have to pull the throttle body because it is on the bottom of it and I read post that for Ford charges $500.00 to do it. Anyway I changed it and no more flashing od light.Or radical shifting either. I had read lot of folks post who had spent $1000s on their vehicle at shops and dealers to only get almost home and it do it again. Some posted they were gonna sue the shops.
Anyway I just wish before I spent all I did, I could found a post like this telling the problem which would have saved me lots of time labor and money . I hope all who are having this problem find this post. I put a 1000 or so miles on it Thanks Giving and no problems.
Trying to fix these without reading the codes wastes a lot of time and money. How do you know that the next person that has a flashing OD light has the same problem that you did? There are about 50 things that can make the OD light flash.
I don't ; But maybe it will help someone that does have same problem with same vehicle. Never know. And I always pull codes. That's how I knew about the block sensor in tranny. But for some reason it wouldn't pull the throttle body sensor which caused me a lot of money and labor. Maybe I didn't explain myself right and for that I will say sorry.
Simply pulling the code fixed it? And X2...what is a 'block sensor' in a trans?
A post on what forum? How about a link? And I guess you mean the Throttle Position Sensor? You seem to think I am lying ; I can prove everything I am saying.
[/QUOTE]
Actually my wife found the post and I would have to do some research to find it again. Yes I meant the throttle body sensor .'typo error'
