Gauges not working
Old Dec 6, 2018 | 02:15 PM
bcamill's Avatar
bcamill
Gauges not working
I have power to my cluster gauges, but they do not work. I did have a problem with the tach that blew the ignition control box under the hood and am not sure if that did it. I did an ohm test on the coolant sensor and got 61 ohms. Not sure what it should be. Any suggestions?
Old Dec 6, 2018 | 02:38 PM
1986F150six's Avatar
1986F150six
If your instrument cluster has all gauges [not idiot] lights, all three gauges other than ammeter get their ~5 volt power through the ICVR [instrument cluster voltage regulator].
Also, if the ignition switch [key] is sticking [cold weather], then sometimes you can wiggle it and the gauges will suddenly work. Does the blower for the heater work? How about the turn signals?
Old Dec 6, 2018 | 03:04 PM
bcamill's Avatar
bcamill
The blower is working. I do have that wiggle thing occasionally. I notice it when the directional do not work or I want the blower on. The power is there as I tested it. I am just wondering if I may have blown the sending units for oil, tem and gas. Or if I may be missing something else.
Old Dec 6, 2018 | 03:12 PM
1986F150six
Are all gauges at rest with the needles at lowest position?
Old Dec 6, 2018 | 03:14 PM
bcamill's Avatar
bcamill
Yes they are
Old Dec 6, 2018 | 03:17 PM
1986F150six
I am getting ready to be away from the computer. I do not believe you will have damaged all 3 sending units. Take the lead off the easiest to get to [on my six cylinder, that would be the oil pressure] and with the key on, temporarily ground the removed wire. Have someone look at the gauge and it should quickly swing to the opposite side. If so, gauges and wiring are good.
Old Dec 6, 2018 | 10:27 PM
ctubutis's Avatar
ctubutis
The dash gauges are totally independent of the ignition & computer systems (if equipped).
Wiring diagrams & ICVR info here:
EVTM - Gary's Garagemahal (the Bullnose bible)
Old Dec 10, 2018 | 04:14 PM
bcamill's Avatar
bcamill
OK, so I got around to grounding the gauges this weekend and no movement. I have the volts there though.
Old Dec 10, 2018 | 04:33 PM
vjsimone's Avatar
vjsimone
What point or wire do you have the "volts" ?
How many Volts?
Old Dec 10, 2018 | 04:35 PM
bcamill's Avatar
bcamill
It is coming in at 6 volts when I take it from the stem on the gauges
Old Dec 10, 2018 | 04:36 PM
FuzzFace2's Avatar
FuzzFace2
So you had 5 volts on that wire you put to ground and the gauge did not move?
If so I don't know if that could happen?
If I under stand how this works you have 12v into the ICVR and 5v out> that goes to each gauge (fuel / oil / temp)> out to the wires to the senders.
So if the ICVR or the gauge was bad I don't think you would get 5 volts on the wire you put to ground. I could be wrong also.
It also seams strange that they would all stop at the same time and as said points to the ICVR
Dave ----
Old Dec 10, 2018 | 04:56 PM
vjsimone's Avatar
vjsimone
Measure for voltage where the wire connects to the Sender Units when you get the chance, but not attached to the Senders.
Old Dec 10, 2018 | 05:08 PM
bcamill's Avatar
bcamill
Will do that next
Thundar76
Mar 11, 2014 09:13 PM
alhorgan
Sep 25, 2012 10:18 AM
SideWinder4.9l
May 2, 2012 10:46 AM
Richie.Rich
Jul 30, 2010 11:39 AM
myEXisFAT
May 2, 2006 05:15 PM
