Sponsored by: Real Truck
Breaking wheel studs
Old Dec 5, 2018 | 10:31 PM
homertwo's Avatar
homertwo
I have a 2000 F550 dually. Last Friday I lost 6 of 8 wheel studs on the drivers side rear. I put 8 new studs in on Saturday.
Today, Wednesday, I was driving 40 miles an hour and all 8 studs sheared off and I lost both wheels. Studs are breaking off inside the hub. None of them were sticking out even a little.
Any idea what the heck is going on?
Thanks for any help.
Old Dec 5, 2018 | 10:54 PM
Colorado350's Avatar
Colorado350
Couple things come to mind. Are they the correct stud for the weight rating? Are you having them pressed in…they should be pressed in not pulled in with a nut. Are you using the correct lug nut for your wheels? Torquing them to specs then again in 50 miles or so?
I went through the same thing with my Jeep, shop pressed in the wrong lugs, almost lost a wheel on I70 here in Colorado.
Old Dec 6, 2018 | 03:21 AM
Chuck's First Ford's Avatar
Chuck's First Ford
wrong studs. with a dually... get studs from Ford !
bad rear axle bearing
bad rear leaf spring bushings
cracked rear leaf spring, or springs.
wheel damaged from the first set of studs broke.
Old Dec 6, 2018 | 06:17 AM
Djosbun's Avatar
Djosbun
Chuck is probably right. Something at that side of the rear suspension has failed, causing a vibration strong enough to snap the wheel studs. Check the shock, spring (and shackle), as well as the wheels (get them balanced).
— Dave
Old Dec 8, 2018 | 11:27 PM
homertwo's Avatar
homertwo
Ok. So far I have been putting on studs from Advance Auto Parts. Bad idea. I bought the expensive ones thinking they were stronger.
I went to Ford and bought theirs. 40 cents more but you can tell that they are by far superior to the other ones.
My wheels were starting to egg shape in the bolt holes. New ones on the way.
I checked the hub when putting in new studs from Ford. Holes were starting to show wear. Picked up the new hub today.
I will check the shocks. New springs last April so I don't think that would cause it.
As soon as the wheels get here, I will change out the hub and put the tires on the wheels. Tires are a month old. Shop where I had the tires put on could not balance the tires so I put some of that tire balance stuff in them.
Thanks for the replies.
Old Dec 9, 2018 | 06:47 AM
TooManyToys.'s Avatar
TooManyToys.
Did the shop that put on the tires use a torque wrench to final tighten the nuts? The typical failure of lug studs is overtightening and the stud is stretched enough that a stress crack starts to form in the thread root. With starting and stopping the shear forces cause the cracks to propagate through the stud and it fails. Once one goes, the others follow quickly. If the holes in the wheels egg out, that causes a differential in the side loading. Ideally, all of the acceleration and deceleration is supposed to be addressed by the clamping force between the wheel and hub, not the studs, but again that depends on the consistency of the bolt tighten methodology.
How studs are installed is just as important because if they are not fully seated all the way, they will move longitudinally and relax, just like not enough torque was used to install the nut. While there are specialized lug nut install clamping tools, a press is the most foolproof way to install replacements. Or a factory hub.
Old Dec 9, 2018 | 07:23 AM
'65Ford's Avatar
'65Ford
X2 on this. I would thoroughly investigate these items first and then look at less likely items like suspension.
Old Dec 9, 2018 | 09:49 AM
Fefanatic's Avatar
Fefanatic
Since it was OK until you had tires installed it's best you check the rest of the tires/wheels/studs. I doubt this is a coincidence. It was probably caused and you should check the rest of the truck. JMO...
Old Dec 9, 2018 | 12:43 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
So do I.
Here is a photo one of my wheel studs, which illustrates exactly what TooManyToys is talking about:
s t r e t c h e d wheel stud.
Old Dec 16, 2018 | 06:52 AM
cmaupin's Avatar
cmaupin
Dang, that is scary. Good to know. hope you get it fixed soon please let us know when completed
Old Dec 16, 2018 | 10:55 PM
homertwo's Avatar
homertwo
Well i put 2 new wheels, a new Ford hub with new studs, and new nuts on Monday of last week. I have about 150 miles on the new setup. All is well so far. I keep checking the torque on the nuts before I drive it.
I sure hope this is the last time I will have to do this.
Thanks for all the replies.
Homer
Old Dec 17, 2018 | 12:13 AM
82_F100_300Six's Avatar
82_F100_300Six
man thats messed up. i remember working on my boat trailer tightening u-bolts and being able to see them stretching. and that was just going easy on them by hand
Rob89
Apr 9, 2018 09:19 PM
Horace18
Nov 18, 2017 04:02 AM
greenmachine86
28
Sep 23, 2016 05:21 PM
Bobs65F600
Nov 6, 2013 06:16 AM
GruesomeJeans
1978 - 1996 Big Bronco
Mar 23, 2013 01:03 AM
