Time for new shocks
Old Dec 8, 2018 | 04:58 PM
maypo59's Avatar
maypo59
Thank you.. everything I seemed able to find was for a 5" lift.. bad search terms or something.. again, thanks.
Old Dec 20, 2018 | 06:29 PM
undl8r's Avatar
undl8r
New shocks needed - can't find full set from Fox or Bilstein, suggestions?
I also need new shocks but am having problems finding a set from Fox or Bilstein with OEM ride height. I am not too keen on Ranchos, but this is based on my experience with two other FX4 trucks. Half my driving is down moderately rough dirt roads that become treacherous with some precipitation (desert clay - other concern with Ranchos is the clay will work its way into the adjustment ****). Does anyone have other information on Fox/Bilsteins' availability (see list below)? Other considerations? (still would consider Ranchos if they can stand up to the 50% off-road driving and other brands i've come across but have no information on - KYB and Skyjacker). I would happily trade firmness/better on-road handling for a smoother/softer off-road ride.
Bilstein B8 5100 Series-Rear only 2"+lift
Bilstein B6 4600 - Front only, OEM height
FOX 2.0 Performance Series Smooth Body IFP Shocks - Front only, 2"+
Thx in advance.
Old Dec 20, 2018 | 07:18 PM
BillyE's Avatar
BillyE
Bilstein still hasn’t gotten their act together and offered a rear shock for our trucks. You can buy some for a 2016 and swap out the bushings.
Old Dec 20, 2018 | 09:14 PM
Imadentguy's Avatar
Imadentguy
im confused as to why these shock manufacturers are so off base. Every other truck i see here in houston is a 17+ superduty. I have a 2 wheel drive and i cant find a set of 4. Its like rancho makes a front but not a rear, and bilstein makes a rear shock but has no front application. Not even monroe makes a set of 4. Shimmy shocks? Fuggetaboudiit....,,,,just dont make no sense....
Old Dec 20, 2018 | 09:21 PM
undl8r's Avatar
undl8r
I'm with you. This truck is in it's 3rd model year and it seems that no-one besides Rancho and few never heard of brands makes a set of shocks for OEM height, stupidest ***** i've seen in a while.
I've put about 23K miles on my truck and it now skates when ever it hits washboards, plus a rock severely dented one of my rears. (base shocks, no FX4). It's total BS that I can't find a solid shock absorber (I've read too many issues with the Ranchos adjustment ring).
Old Dec 20, 2018 | 09:28 PM
undl8r's Avatar
undl8r
thanks.
how hard is it to remove and reinstall the bushing? i assume you do it to both ends. are mounting points the same distance apart (16'- vs. 17+)? i may have to go this route.
Old Dec 20, 2018 | 09:41 PM
TXKR's Avatar
TXKR
From the Fox website, OEM height for F250 4x4::
​​​​​​PERFORMANCE SERIES 2.0 SMOOTH BODY IFP SHOCK Front 4WD 0-1.5" 985-24-154 $139.95
​​​​​​PERFORMANCE SERIES 2.0 SMOOTH BODY IFP SHOCK Rear 4WD 0-1" 985-24-151 $139.95
I had the Rancho 9000XLs on my 2015 for a brief time before I traded it and was not impressed. On the set I bought the little adjuster ***** were a beast to turn, even after removing and lubricating them. And the welds that held the eyes onto the bodies were tiny and just looked weak. I just installed the Foxes last weekend on my 2018 and could not be happier.
Old Dec 20, 2018 | 09:55 PM
Maximus216's Avatar
Maximus216
Front: RS999042
Rear: RS999047A
These are for a 2018 F-250 4wd 6.7L at stock height.
Joseph lake
Tenneco Technical Resource Center
Rancho Suspension
1-734-384-7804 M-F 8:30am-5:30pm EST
undl8r's Avatar
undl8r
Thanks. Weird that many of the online retailers don't list it. Found them at Stage3. Have you gone on any rough or off road with them? Curious as to how they compare with stock - stiffer, softer, rebound? I did install the Fox steering stabilizer and have been very happy with it.
Old Dec 20, 2018 | 10:08 PM
TXKR's Avatar
TXKR
Tire Rack sells them with no tax and free shipping for $139.95 each. I have not used them offroad but I can already tell they will perform well. They are quick to suppress the rebound, but are not harsh. If I had to put a number on it for reference, I'd say the truck is 20-25% stiffer with the Foxes over stock.
Old Dec 20, 2018 | 10:10 PM
Imadentguy's Avatar
Imadentguy
Originally Posted by Maximus216
Front: RS999042
Rear: RS999047A
Joseph lake
Rancho Suspension
Thank you sir i greatly appreciate it.... but i have a 17 6.2 2wd :-(
Old Dec 20, 2018 | 10:21 PM
TXKR's Avatar
TXKR
Suggest you maybe put that in your signature line so folks know which truck you own. The settings are in the User CP under Edit Signature.
Old Dec 20, 2018 | 10:58 PM
  #28
Imadentguy's Avatar
Imadentguy
cool thank you. Ill give it a shot.
Old Dec 21, 2018 | 04:41 AM
  #29
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
I just received my Rancho 9000 xl's . I like the adjustability and warranty . Hope to get them installed over Christmas break .
Old Dec 21, 2018 | 06:24 PM
  #30
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Got them yesterday . Already removed adjustment **** and put a little lithium grease , I also got them clearcoated . Probably not necessary for my location , but it can't hurt !
