Time for new shocks - Page 3 - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Time for new shocks
  #31
Old 12-21-2018, 10:28 PM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
Originally Posted by RONMCHUGH View Post
Got them yesterday . Already removed adjustment **** and put a little lithium grease , I also got them clearcoated . Probably not necessary for my location , but it can't hurt !
Great job!
Do they still come with the red shields?
  #32
Old 12-21-2018, 11:22 PM
Mud Doc's Avatar
Mud Doc
Mud Doc is offline
Mud Doc is starting off with a positive reputation.
I think the red shields on the OEMs were just for marketing--basically Ford shocks with Rancho branding? Don't last any longer than the OEMS do, in my experience. Needing to do something with my 450 at 46k miles--rears feel like they are shot.
  #33
Old 12-21-2018, 11:30 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
My OEM non-Rancho shocks were toast within 5,000 miles. One was obviously leaking, none of them rode well. New Rancho 9000XL shocks came with the plastic boots.
  #34
Old 12-22-2018, 05:08 AM
RONMCHUGH's Avatar
RONMCHUGH
RONMCHUGH is offline
RONMCHUGH is starting off with a positive reputation.
Originally Posted by wrvond View Post
Great job!
Yes they did come with the boots . Hope to get them on without them looking cheesy !!!
  #35
Old 12-22-2018, 06:11 PM
RONMCHUGH's Avatar
RONMCHUGH
Got them on today since it was 76 * here . I took a side by side pic to show the obvious difference in size . Front took the longest just because of the threaded stud on top . Rears took 10 minutes . I happened to have some red zip ties , so I used those to tie the boots on . Seems to be a little less noticeable than the black . As others have suggested , I am starting at setting 6 on the front and 4 on the rear . I will take for a test drive tomorrow that is longer than a mile .
Front done .
Rear side by side ..
I also noticed that they are stamped FOMOCO with Rancho decal .
  #36
Old 12-22-2018, 06:15 PM
Imadentguy
Imadentguy is offline
Imadentguy is starting off with a positive reputation.
NICE! Im jelly for sure!
  #37
Old 12-23-2018, 06:39 PM
RONMCHUGH's Avatar
RONMCHUGH
Went for a few longer rides today . Definitely a difference . Bumps don't seem to be as harsh , but didn't feel like I was floating either . Took the wife to kids house and she even noticed the difference . All is well !!!!
  #38
Old 12-26-2018, 01:58 PM
pesty3782
pesty3782 is offline
pesty3782 is starting off with a positive reputation.
Getting ready to purchase these shocks...Thanks for the info...80% driving is without 5th wheel so the adjustability of these shocks should serve me well.
Tony P.
  #39
Old 12-26-2018, 08:07 PM
Faceplant409's Avatar
Faceplant409
Faceplant409 is offline
Faceplant409 is starting off with a positive reputation.
I had Bilstein 5100s on my 06 and I loved them. 80% freeway. I like a firm ride.
  #40
Old 12-27-2018, 10:20 AM
pesty3782
Ordered up the shocks yesterday now do I need to clear coat them? I live in southern California and wasn't sure why people clear coat them before install
Tony P.
  #41
Old 12-27-2018, 10:30 AM
powersrp
powersrp is offline
powersrp is starting off with a positive reputation.
They clear them for added protection paint protection, need 50 coats here in michigan
  #42
Old 12-27-2018, 12:14 PM
Tricon's Avatar
Tricon
Tricon is offline
Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.
Tony P.
In SoCal, no, you definitely do not need to clear coat them. Most people in frigid areas will clear to protect from the crazy salt/slurry chemicals they throw down on the roads in the winter. It eats cars alive.
Just keep them clean, if you have a higher end shock like a Fox/King/SAW you can wax them once a year or so and they'll look brand new for a decade.
  #43
Old 12-27-2018, 01:42 PM
Spence144db's Avatar
Spence144db
Spence144db is offline
Spence144db is gaining momentum as a positive member of FTE.Spence144db is gaining momentum as a positive member of FTE.
You sir are dead on... I did a job for TENNECO Automotive building a robotic vision inspection machine for them to check for paint defects and correct sticker placement on RANCHO shocks... I personally wrote the program for that machine and it was set up for only one pass...it took the parts from the same line and checked all of them. Then just before seam roller welders that weld that little checker pattern on the top of you OEM shocks is the fill station and RANCHOS come off the exact same lines as the rest of the non RANCHO shocks...They claim an oil difference but I never saw them while I was at the plant for 4 months....
  #44
Old 12-27-2018, 04:09 PM
RONMCHUGH's Avatar
RONMCHUGH
Tony P.
I think a lot of guys up north do it because they salt the roads . I did mine just because it couldn't do any harm and it gave me a warm and fuzzy knowing it was done . I also removed the adjustment screws and put a little grease in the cavity .
  #45
Old 12-27-2018, 07:47 PM
kcwolf200
kcwolf200 is offline
kcwolf200 is starting off with a positive reputation.
I am considering getting the Rancho 9000XL's. I've never installed shocks before. How hard are they to install?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
