Swap is done....
Old Dec 11, 2018 | 08:01 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Skip1970
can you run duals with the weird 1 o2 sensor that goes in the y??? is it ok to just put it on one side?
Why is the one oxygen sensor weird? Only one sensor is needed and having it in the “Y” samples the exhaust coming from both banks.
Yes. You can
Old Dec 11, 2018 | 08:04 PM
Skip1970's Avatar
Skip1970
its weird due to the mountng of it if you were to move it to just one side on true dual wouldnt it think the stream is lean due to only 4 cylinders?
Old Dec 11, 2018 | 08:20 PM
frank5079's Avatar
frank5079
Since I am running the Y-pipe(which is actually more of an H-pipe) from an F250, my O2 sensor is located on the crossover balance tube that connects the left and right banks....
Old Dec 11, 2018 | 08:40 PM
Skip1970's Avatar
Skip1970
thats what i was thinking of doing.
Old Dec 12, 2018 | 02:58 AM
My4Fordtrucks
No. It would only be lean on that one side if you had an air leak upstream of the sensor.
Old Dec 12, 2018 | 09:39 AM
Tommy_T's Avatar
Tommy_T
Nice work!
Old Dec 17, 2018 | 04:32 PM
couleeman23's Avatar
couleeman23
Exhaust is on. Was able to salvage most of the exhaust from the donor truck.
Matthew Kasper
1978 - 1996 Big Bronco
22
Apr 24, 2014 09:26 AM
NJK570
13
Sep 18, 2012 11:11 AM
00fordman16
Exhaust Systems
Jan 1, 2008 09:37 PM
SierraClubS
2004 - 2008 F150
Jan 18, 2005 09:59 AM
elwood
45
Jun 14, 2003 12:01 PM
