installed front disc brake kit, blead the brakes around 7 times each wheel, no leaks any place, but if I let it set for awhile and then go back and hit the brakes pedal goes to the floor, then on the second pump I will get a good pedal. this is on a 65 F-100 4WD. Already had power drum brakes so I used the same booster and master cylinder, any ideas what's wrong!!! thank
Disk brakes take less pressure to operate than drum brakes. The master cylinder will be different in a disk/drum setup than it is in a drum/drum setup. The disk brakes have a larger piston and no springs like the drum brakes do. A master cylinder setup for disk/drum will have a built in metering block in combination with the proportioning valve. Another thing to try is to have residual valves in the brake lines. I bought some several years ago from Speedway Motors. They sell a 2 PSI residual valve for disk brakes and a 10 PSI residual valve for the drum brakes. The valves hold a bit of back pressure in the lines so your pedal does not go soft. It is a kind of a one way valve.
Did you use the valve on drum or disk?
Did you like them?
Thanks,
I used the drum valve. I have a dual master cylinder and used one on the brake line going to the front and the other to the rear line. Both are the 10 PSI valve. I have a 1964 F250 with a camper built onto the bed. It weighs a ton and is hard to get stopped. The residual valves really help with the dead pedal problems.
WoW! Excellent news.
Sounds like a plan for my 250.
If this helps with the pedal and, then for $30.00, way to go.
Thanks,
