Clutch equalizer bar question
Old Dec 2, 2018 | 08:06 PM
Crownvicguy's Avatar
Crownvicguy
I just purchased a 1949 mercury m47 from canada. It was a farm truck and im trying to get it back on the road again. The clutch equalizer bar has 'popped' off the ball socket mounted to the frame. Im thinking there is a bushing that is supposed to go in there but not sure. My question is, how does it contect to the socket? Is it push on? Thank you for any help.
Old Dec 3, 2018 | 12:46 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to the forum! Congrats on your purchase!
Yes, there is a bushing on the ball, actually a split bushing (2 pieces) that go on the ball, then the equalizer slides over them. The bushings frequently crack or wear out. Replacements are available in original bronze or modern plastic. There should be a spring inside the equalizer too.
p/n C2TZ-7517-A, VanPelt Sales has them: VANPELT SALES LLC - your ford flathead source since 2006
Old Dec 3, 2018 | 08:30 AM
Crownvicguy
Thank you for the response and link!. Does it just 'push on' 'pull off'. Any special tool or technique to do this?
thank you
John
Old Dec 3, 2018 | 09:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
With the equalizer off, grease the ball, stick the bushings onto it, slide the end of the equalizer over the bushings (with the spring inside), then slide the other end onto the clutch shaft on the bellhousing. Insert the pin and cotter pin.
Van Pelt shows the old p/n for the bushings, and only for '40 - '48, but he has the correct ones. Might want to call to verify before ordering. Others sell them, buy wherever is closest to you.
Old Dec 3, 2018 | 05:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C2TZ-7517-A (replaced 01A-7517) .. Split Bronze Clutch Equalizer Shaft Bushing / .996" O.D. x .847" I.D. x .58" long / Obsolete
1940/47 all Trucks / 1940/48 Ford/Merc Passenger Cars / 1948/52 F1/F8 & F3/F5 Parcel Delivery & F5/F6 COE / 1949/59 Ford Passenger Cars / 1955/60 Thunderbird / 1961/64 F100/750 / 1963/69 N500/750.
You will need 2 of these puppies, each contains the upper & lower section.
RPN PARTS in Erie PA has 4 = 888-666-0916.
GRANDE TRUCK SALES in San Antonio TX has 8 = 210-661-4121 x 147.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 47 = 800-476-9653.
Old Dec 3, 2018 | 06:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The two halves are identical, only need a total of 2 half-bushings (sold as a set everywhere I know).
Old Dec 3, 2018 | 06:42 PM
NumberDummy
Parts catalog lists 2, which I would assume would be 4 pieces. There's no pic of the OP's setup in the 1948/56 truck catalog.
Pic of 1961/63, notice each side uses 2 halves, one total piece.
Old Dec 3, 2018 | 08:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
This is the illustration for a '49. Only 1 set of 2 needed. The round piece to the left of them is a felt seal that keeps grease in, dirt out.
Old Dec 3, 2018 | 10:01 PM
Crownvicguy
Really appreciate all of your help! I ordered the parts from the link above. Man on the phone was very knowledgable. I hoping that its just a bushing problem and not another issue cause the equalizer to pop off. However, the gentleman said the little 'ball' piece is supposed to start being made available around Jan 2019. He said they have not been made for a long time, so many people will be happy to hear the are being reproduced.
Old Dec 3, 2018 | 10:04 PM
Crownvicguy
Im sorry i forgot to mention, i used the van pelt link.
Old Dec 4, 2018 | 12:27 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If it came off during normal operation, you may want to read this thread: https://www.ford-trucks.com/forums/1...too-short.html
The relevant solution is on page 3 of that thread. If you can pull the trans cover off (seat really needs to be out), and remove the inspection cover on the top of the bellhousing, you should be able to see if the clutch fork has spread. Another clue (quicker and easier) is to see how much you can move the clutch fork shaft in and out of the bellhousing. You should not be able to move it more than 1/16" - 1/8" at most.
Sid138
Sep 12, 2012 10:06 AM
hermancm
Jun 5, 2012 07:33 PM
andbluesman
Jan 2, 2011 06:10 PM
Rubenk
25
Sep 12, 2010 03:09 PM
timber_cruiser
Feb 18, 2010 07:19 PM
