Stock Interiors
Old Dec 1, 2018 | 03:27 PM
Azryael's Avatar
Azryael
Stock Interiors
Anyone ordered from them before? I've grown tired of my gray carpet and want to transition to black.
Was the fit correct? Did they actually cut out for the 4WD and 5-speed if you selected that option?
Is the mass backing they offer for an additional $73 worth it?
Old Dec 1, 2018 | 05:15 PM
humphrey169's Avatar
humphrey169
I dyed a blue carpet black once. Still good 3 years later
Old Dec 1, 2018 | 05:33 PM
Azryael's Avatar
Azryael
My carpet has holes and rips that even dying just won't fix. I'm looking at replacing the whole deal.
I dyed some pieces on my older MBs, but those were small jobs and the interior was already black. Just repairing UV fade.
Old Dec 1, 2018 | 06:51 PM
ArmyRover's Avatar
ArmyRover
Curious about this as well. New carpet is on my to do list
Old Dec 1, 2018 | 08:13 PM
rdfact's Avatar
rdfact
Their installation video indicates you will need to make cutouts for seat mounts, center console, etc and perhaps even trim because the new carpet may be oversized.
The video also mentioned a "Cut & Sewn" option that has the cutouts already and should be a direct fit, but that seems limited to certain vehicles.
https://www.stockinteriors.com/Install.asp
Old Dec 1, 2018 | 08:15 PM
95fiveoh's Avatar
95fiveoh
My carpet is from ACC, I bought it from RockAuto. It fit pretty well but still required some trimming as should be expected. Definately pay extra for the mass backing, if you don't the carpet with feel thin and cheap. It also provides some noise insulation.
Old Dec 1, 2018 | 08:21 PM
Azryael's Avatar
Azryael
Good to know. I figured there may be some trimming involved, but seeing as how they have "options" for whatever your truck might be, it seems to me they'd go ahead and cut things out!
I will keep my old one as an overlay to mark the holes as needed then I guess.
This week I'll be making some new sill plates out of aluminum up at the shop.
Old Dec 1, 2018 | 08:35 PM
95fiveoh's Avatar
95fiveoh
Yeah, keep the old one and use it as a template. The reason they have options for what your truck is because the 4x4 and stick shift trucks have a bigger hump over the transmission tunnel. They don't cut anything out, you have to do all that yourself.
Old Dec 1, 2018 | 08:43 PM
Azryael's Avatar
Azryael
Really? When I did my auto to manual swap, the trans tunnel cover between the auto and the manual was the exact same size. The manual cover just had the cutout for the shifter.
4x4 shifter cover plate is on the side of the tunnel, and that looked no different than the '89 my ZF5 and 1356 came out of, nor did the rest of the trans tunnel.
Perhaps the larger humps are for the '80-86 trucks?
In fact, when I did the clutch replacement on the '94 5-speed IDI, it looked identical to my '96 which had started off life as an auto.
Old Dec 2, 2018 | 11:22 AM
95fiveoh's Avatar
95fiveoh
Maybe I'm mistaken but my understanding was that if a truck came with 4x4 and/or a manual transmission, it got the larger transmission cover. The smaller hump transmission covers only came on 2wd automatic trucks. I think this was the same for 80-96.
Old Dec 2, 2018 | 12:33 PM
Azryael's Avatar
Azryael
Wonder if it was based on motor then. Larger bellhousing for the big blocks might have demanded larger humps that were identical between gas and diesel versus the small blocks and straight 6?
colesvsu
Apr 21, 2011 07:10 PM
Futuresweets-10
Feb 5, 2010 04:47 PM
dontrowell
2009 - 2014 F150
Mar 19, 2009 09:30 AM
move
15
Jan 14, 2006 07:56 AM
gccch
2004 - 2008 F150
Feb 13, 2005 02:33 PM
