Automated Washing
Old Nov 29, 2018 | 03:16 PM
jnphobe's Avatar
jnphobe
I run my dually thru an automatic wask with out brushes all the time and it gets a blow dry at the same time, does a nice job.
Old Nov 29, 2018 | 04:02 PM
kkirt1's Avatar
kkirt1
I have taken my last two trucks through the local car wash. Before that I use to be a drive in bay wand cleaner guy and was always disappointed at how poorly they cleaned. If I had black paint I might reconsider but the automatic is so convenient and does a great job no way would I go back to the wand.
Old Nov 29, 2018 | 07:01 PM
coriolis2k's Avatar
coriolis2k
is there a preferred wax the group likes....for a darker color (magnetic) truck?
Old Nov 29, 2018 | 07:16 PM
HRTKD's Avatar
HRTKD
Oh, my. That's like asking what oil is the best.
I use a synthetic wax/sealant from Adam's Polishes that I can put on with a machine polisher. I despise carnauba based waxes. They may look great but they're just too much work. For a dark paint you'll probably need some actual polish eventually to eliminate the swirl marks. My wife's Hyundai Santa Fe needed polish before it had 20,000 miles. I had her help so could understand why I don't like dark color vehicles.
Old Nov 29, 2018 | 08:36 PM
slip knot's Avatar
slip knot
I've ran my 2019 thru the brush wash a couple of times now. 1st time the factory running boards weren't cleaned at all. learned I must brush them with the prewash prior to running it thru the tunnel. 2nd time I had replaced the radio antenna with an 8in stubby one so it wasn't trying to yank it out. 3rd time down the tunnel I noticed that the brush missed the middle of the tailgate completely. gotta remember to pull the hitch next time.
Every time I've gone thru, as we're exiting the tunnel after all the blowers have dried the truck there is a ton of water run off the roof across the windshield, foamy soap, wax and all. it usually smears the windshield after that. I asked about this in the "do I need a level kit" post. Am I the only on who notices all the drainage off the roof comes over the windshield?
Old Nov 29, 2018 | 08:49 PM
HRTKD's Avatar
HRTKD
I haven't noticed that amount of drainage coming off my room in the car wash. As tall as my truck is, the roof is right up against the blower so it gets maximum MPH thrown at it.
Old Nov 29, 2018 | 09:06 PM
xxxsherpa's Avatar
xxxsherpa
Mine is the same. I have to chamois the side mirrors though.
Old Nov 29, 2018 | 09:42 PM
jrwinger's Avatar
jrwinger
I have a monthly membership at a local carwash. It's the type that it runs through a tunnel wash & then a bunch of guys/gals hand dry, polish and wipe down the interior/exterior. For me, the time savings of hand washing myself is worth it alone.
I wax my truck every 6 months or so. I usually clay bar it, and then wax it. Takes a solid day to clay and then wax the beast, but worth it to keep her looking good.
I love being able to run it through as often as I'd like. Truck always looks good!
Old Nov 30, 2018 | 11:16 AM
BnG250's Avatar
BnG250
Automated Washings
I do the same as Donjamer had mentioned, I have my own brush that I clean before and after use and store in a breathable clean bag. We just go a new Rocket Wash and they said my truck may not fit, but I could proceed at my own risk. I have had two previous trucks damaged by automated washers and don't want the hassle. Living in the snow and salt belt is tough on a nice vehicle. I put a good 1-2 coats of wax on in the late fall and then use my brush at self service wash stations when they are not busy. Spring and summer I wash and wax again. I agree with what most are saying in that the automated touchless washes don't really clean everything off, you still have a 'salt shadow' left over. Also, I like to spray the underside, as Ford did not do the best job of rush proofing. Yes, the body is aluminium, but drivetrain and fasteners will corrode rather quickly.
Old Nov 30, 2018 | 11:43 AM
wicked 2018's Avatar
wicked 2018
I just use a pressure washer with de-ionized water - with a foam sprayer. Give it a quick rub down after foam is applied, rinse, hit the big drops with my blower and let air dry the rest. Takes me more time to setup (bring pressure washer out, DI system, etc) than it does to actually wash my truck. In the end setup to clean up is about 15-20 minutes of my time since it doesn't need to be hand dried.
Wolfjohn
Paint & Bodywork
Mar 14, 2014 10:25 PM
firemanpat29
May 25, 2010 02:10 PM
crazyeddie
Appearance & Dress-Up
Oct 28, 2009 09:13 PM
laynrubber
Jul 25, 2005 12:08 AM
VPW
Aug 6, 2003 10:57 AM
