1976 F250 Decode
Y = 360 2V
R = San Jose CA Assembly Plant.
A77760 = 1976.
133" Wheelbase.
8 = Dark Yellow Green Metallic.
F261 = F250 4WD Pickup; 7600 lbs. GVWR
DG4: DG = Green all Vinyl - Custom // 4 = Styleside Pickup.
A = New Process 435 4 Speed Manual Transmission.
24J: 24 = Dana 60 Rear Axle / 4.10-1 / 5,300 lbs. Rear Axle Capacity // J = Bendix Power Assist Power Steering.
7,600 lbs. Gross Vehicle Weight Rating.
1976.
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
Note: The engine has been swapped, it may be a 360, but it could also be a 352 or 390 or who knows. 1965/71 FE engines have a casting foundry mark of 352.
Beginning in 1972, the FE casting foundry mark is a reverse 105. FE engines have 5 valve cover bolts per side. If it is an FE, you'll have to measure the stroke to determine what size it is.
Please ask further questions in the 1973/79 F100 and larger truck forum. This is the LARGE TRUCK forum for 500 and larger series BIG trucks.
Adammc224
01-14-2019 04:56 PM
Mr. Keebler
02-21-2018 03:37 PM
blucollar4xford
23
03-06-2007 11:12 AM
