leaf spring dimension / swap question
Old Nov 27, 2018 | 08:30 AM
94windsor's Avatar
94windsor
I have a 1971 F-350 Dually that I plan to customize a little. Part of which would be lowering. I already know about and have obtained info for direct fit beams, however I am looking at different ways to lower the rear and improve the ride. I was thinking about removing leafs or swapping in either F-250 or even F-100 spring packs. Other than occasional hay hauling I just drive the truck as is. That 11,000 gvw is a bear on the guts and not to mention the little lady isn't thrilled with the ride.
My question is - Are the spring hangers / perches the same throughout the F series line? Would other truck spring packs fit without having to move the mounts?
Thanks in advance for any help!!!
Old Nov 27, 2018 | 08:37 AM
351Cleveland C4's Avatar
351Cleveland C4
Not sure about F350s. They might be different than 100/250. But you can probably just yank out the bottom half of the spring pack and be good. Depending in how many leaves are on each side, you want to leave about 5 or 6 probably. Or just leave about 4 and install some air bag springs to help out.
Old Nov 29, 2018 | 01:43 PM
94windsor's Avatar
94windsor
Thanks!
I still have the overload springs so that would help with a load. Probably won't work it much once I finish it. My plan is for the exhaust to come up through the bed ala diesel style. It is a flat bed so any hay hauling might turn in to an inferno!
Looking at exploded views on FORDification.com and everything looks the same from 100/250/350 just no dimensions.
Old Nov 29, 2018 | 07:12 PM
Phantomtruck68's Avatar
Phantomtruck68
General springs has all the dimensions you asked for on their web sight.
https://www.generalspringkc.com/Leaf_Springs_Ford_Truck_s/1861.htm
Old Nov 29, 2018 | 10:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/72 F350's have 6, 9 or 10 leaf rear springs. The 6 (C7TZ-5560-F) leaf and 9 (C7TZ-5560-G) leaf rear springs are the same as 1967/72 F250's without Flex-O-Matic.
These springs are 2 1/4" wide .. 26.00" > > eye bolt < < 26.00."
Old Nov 30, 2018 | 06:24 AM
94windsor's Avatar
94windsor
Thank you both for the valuable info. I have the 10 leaf pack.
jimcar-9
Oct 31, 2014 12:36 PM
dave47111
Dec 14, 2011 03:40 PM
struttin
Sep 22, 2011 07:50 AM
TUFFY
Mar 18, 2008 08:40 PM
abcat12
Jun 20, 2006 02:36 AM
