spring to life
Old Jun 17, 2006 | 08:24 PM
abcat12's Avatar
abcat12
spring to life
If a HD 150 shares the same spring as a 250 (3" wide) and a HD 250 fits a 350. then will a 350 springs fit a 150 with a 9" rear? My 150 has a broken leaf and i want to swap up but i want to avoid excessive saging if a pull trailers.
Old Jun 18, 2006 | 02:21 PM
DT 466Man's Avatar
DT 466Man
yes, i just did the same thing. Replaced mine with 1ton chassie cab F350 springs. Went from having 3leaves an an overload on each side to 6 leaves and 5 leaf overload.
Old Jun 18, 2006 | 02:38 PM
big hoss 29's Avatar
big hoss 29
I would think that with that many leaves it'd ride like a mexican jumping bean. I know that in my F-250HD, the ride on a bumpy road leaves a lot to be desired and if I had an F-150, I wouldn't want the ride to be that hard.
Old Jun 18, 2006 | 08:49 PM
abcat12's Avatar
abcat12
yeah hat was one of my fears too. but the truck will need to work. so i guess you cant get it both ways. do they make air bag kits for those old trucks that either stay stock height or raise?
Old Jun 18, 2006 | 10:46 PM
plowpusher's Avatar
plowpusher
the biggest problem with using an f150 for hauling heavy trailers is not springs but brakes they aren't big enough. as for air bags just google air bag suspension there are sites that carry bags for older trucks
Old Jun 19, 2006 | 12:01 PM
1982fordf100's Avatar
1982fordf100
Also another issue with carry a heavy load is that the bearings in the rear end are not able to withstand the extra weight. I know that on my 82 F100 we broke 4 leafs on each side when we carried too much weight. Luckly we only did that once and had to replace the springs, but the bearings didn't fail that time.
Old Jun 20, 2006 | 02:36 AM
Piffery1's Avatar
Piffery1
Gee, what kind of trailers are you going to try to pull with an F150? A properly loaded trailer should put 10-15% of its gross weight on the trailer tongue at the hitch (1000-1500 lbs on a 10,000 gross trailer). And with that size load you surely need trailer brakes. Gross (rear) Axle Weight Ratings for 1983 F150's range from 3123 to 3730 lbs.
